Electronics Hardware
Links
SSR Direct Attach
Kit74
Hill320
Olsen 595/Grinch
 - Documentation: Olsen 595
Firegod
 - Documentation: Firegod
Renard
Lynx
- Controlled through: DMX
Helix
 - Documentation: Helix
LedTriks
Triks-C
LEDTRIKS LED PANELS
PIX-C
 - Documentation: PIX-C
JEC Pixel Displays
rgbLED
Color Stick
 - Documentation: Color Stick
- Documentation: Super Strip
RS485 Splitter
FM Transmitters & Antennas
Almost everyone that builds a system to synchronize their lights to music broadcasts that music on a local FM frequency.  This section covers the DIY aspects of FM Transmitters and Antennas.
DMX Boards, both converters and light controllers
			Renard SS 8
			Renard SS 16
			Renard SS 24
			RPM USB to DMX Adapter
			RPM DMX4 SSR
			RPM DMX16 SSR
			RPM DMX8 DC SSR
			RPM DMX16 DC SSR
Digital Input/Output Cards
