Simple Renard 32 Combo
Revision as of 01:57, 2 April 2012 by Jklingert (talk | contribs) (Mouser)
Simple Renard 32 Combo - 32 Channel Controller
THIS SECTION IS UNDER CONSTRUCTION. IT IS NOT CORRECT, PLEASE CHECK BACK IN A FEW DAYS... The Simple Renard RGB+W is a low cost 32 channel DC controller designed to drive low current DC loads like RGB+W LED flood lights (such as DIYC Flood, Mighty Mini or Frank's Super Strip). Unlike other DC designs like the REN48LSD , the Simple Renard RGB+W makes use of a different PIC, the PIC18F4520. This PIC allows 32 chanels per PIC to be controlled compared to the usual 8 channels per PIC (16F688) used in most Renard designs. This allows a smaller board and lower total cost. The design uses low cost NPN bipolar transistors to switch the loads to ground to power the outputs.
THIS SECTION IS UNDER CONSTRUCTION. IT IS NOT CORRECT, PLEASE CHECK BACK IN A FEW DAYS... The Simple Renard RGB+W uses a similar architecture for the logic portions of the board as the RenardSS series of boards. Sequence information is passed from a PC running Vixen or other sequencing program via an RS-485 interface. The RS485 chip receives this information and turn into standard TTL logic levels that the PIC can understand. The PIC reads in the data and if it determines that the information corresponds to itself, it updates the dimming levels of all 32 channels. It removes this information from the stream and feeds the rest out to the RS485 chip which translates it to RS-485 levels for the next controller in the line. It is important to realize that the information is removed from the stream and that the resultant leftover stream will have all of the data offset by the 32 channels of information used by the Simple Renard RGB+W. For example, if you have two Simple Renard RGB+W, on Vixen you would configure a single Renard plug-in with 64 channels. The first SImple Renard RGB+W consumes the first 32 channels of information leaving only 32 channels on it's outputs. The second Renard RGB+W will see this incoming data as controller #1 again and assume the data is for it. This is very much different than standard hard/soft-coded DMX or LOR devices that use a set address yet still pass on the entire stream to the next controller on the line.
THIS SECTION IS UNDER CONSTRUCTION. IT IS NOT CORRECT, PLEASE CHECK BACK IN A FEW DAYS... The Version v.1b is currently the most recent version of the Simple Renard RGB+W in production.
Simple Renard RGB+W Parts
PartDescriptionMouser PNQty
P1Fixed Terminal Blocks 5.08MM VERTICAL 2P wire protector571-79694921
BR14 pin Bridge rectifier 1amp dip625-DF02MA-E31
C1470uf 25V Electrolytic647-UVZ1E471MPD1
C2220uf 25V Electrolytic647-UVZ1E221MPD1
D1Zener Diodes 4.3 Volt 0.5 Watt)78-1N5229B1
D2Zener Diodes 9.1 Volt 0.5 Watt)78-1N5239B1
IC2RS-485 Interface IC LP Diff Pairs595-SN65LBC179P1
IC3H11AA1 Zero Cross782-H11AA11
IC4Linear Regulators - Standard 1A Pos Vol Reg512-LM7805CT1
IC1Microcontrollers (MCU) 32KB 1536 RAM 36I/O579-PIC18F4520-I/P1
ICSPHeaders & Wire Housings FLAT HEADER 6P Straight Post tinr571-64045261
JP1 XBee headerHeaders & Wire Housings FLAT HEADER 5P Straight Post tin571-640452-51
Shunt for XBheader and PIC bypassHeaders & Wire Housings Mini Shunt .177" height737-MSC-G2
J1-J10Ethernet & Telecom Connectors 8 PCB LO PRO R/A571-5555164-110
Status LedStandard LED - Through Hole YELLOW DIFFUSED604-WP132XYD1
Power LedStandard LED - Through Hole RED DIFFUSED604-WP132XID1
RX/TX LedStandard LED - Through Hole GREEN DIFFUSED604-WP132XGD1
R1,R2,R8,R9,R10Carbon Film Resistors - Through Hole 1.0Kohms 0.05291-1k-RC5
R3,R5Carbon Film Resistors - Through Hole 330ohms 5%291-330-RC2
R6Carbon Film Resistors - Through Hole 10Kohms 5%291-10k-RC1
R7Carbon Film Resistors - Through Hole 120ohms 0.05291-120-RC1
R11,R12Carbon Film Resistors - Through Hole 27Kohms 5%291-27k-RC2
IC & Component Sockets 6P DUAL WIPE DIPSKT571-1-390261-11
Wallwart 9-12 volts AC only 507-XT12201
Housing
The Simple Renard 32 Combo was designed to fit in the CG-500 Demarcation Enclosure available from numerous vendors including www.wlcventures.com
  2. Install the resistors:
    1. Install the 1K ohm resistors at locations R1,R2,R6. The resistor are not polarized, so they can go either way.
    2. Install the 330 ohm resistors at locations R3,R7. The resistor are not polarized, so they can go either way.
    3. Install the 10K ohm resistor at location R4. The resistor is not polarized, so it can go either way.
    4. Install the 120 ohm resistor at location R5. The resistor is not polarized, so it can go either way.
    5. Install the 27K ohm resistors at locations R9,R10. The resistor are not polarized, so they can go either way.
    6. Install the 820 ohm resistors at locations R11-42. The resistor are not polarized, so they can go either way.
  3. Install the capacitors:
    1. Install the 47uf Electrolytic Capacitors at locations C1,C2. The capacitors are polarized. The side of the capacitor will have a stripe on the negative side. The long lead is the positive side, and it goes in the hole marked with a +.
    2. Install the 0.33uf Ceramic Capacitor at location C6. The capacitor is not polarized, so it can go either way.
  4. Install the IC sockets:
    1. Install the 8 pin socket at location IC1. The notch on the socket should face the right side of the board, matching the silkscreen image.
    2. Install the 40 pin socket at location IC2. The notch on the socket should face the right side of the board, matching the silkscreen image.
  5. Install the diodes:
  6. Install the transistors:
    1. Install the PN2222AG NPN transistors at locations T1-32. The transistors are polarized and can only go one way. The transistors should be installed with the flat side matching the silk screen image. T1-16 on the top side of the board should have the flat side facing to the right side of the board. T17-32 on the bottom side of the board should have the flat side facing to the left side of the board.
  8. Install the headers:
    1. Install the 5 pin header at location JP2 (RENW header). The short side of the header strip goes into the board.
    2. Install the 2 pin header at location JP3 (VREG bypass). The short side of the header strip goes into the board.
    3. Install the 3 pin header at location JP4 (PIC bypass). The short side of the header strip goes into the board.
    4. Install the 6 pin header at location ICSP (PIC programing header). The short side of the header strip goes into the board.
  9. Install the 5v linear regulator at location IC3. The voltage regulator is polarized and goes only one way. Gently bend the leads of the regulator at the location on the leads where it changes size down at a 90 degree angle towards the flat side of the regulator. Apply thermal grease to the flat heat sink side of the regulator and fasten it to the pcb using a #4 screw and nut.
  11. Install the 2 terminal strips at locations TB1,TB2. The side where the wires enter under the screw should face the right of the board.
  2. If you have any of the IC's (IC1, IC2)installed - remove them now.
  3. Connect your power supply to the “TB1 (V+1)” - it supplies power to controller portion of the board as well as outputs 1-16. “TB2 (V+2)” is a separate input to drive outputs 17-32. Note that the ground is shared between the two inputs. If you are using a well regulated +5vdc power supply as your power input, the regulator circuit should not be installed. However, you must manually bypass this by placing a jumper on header JP3.
  5. Install the ICs:
    1. Install the PIC18F4520 in the 40 pin socket at location IC2. The IC is polarized. Gently install the IC so that the notch faces towards the right matching the socket and the silkscreen.
    2. Install the SN65LBC179P in the 8 pin socket at location IC1. The IC is polarized. Gently install the IC so that the notch faces towards the right matching the socket and the silkscreen.
Programming the PIC
Final Testing
THIS SECTION IS UNDER CONSTRUCTION. IT IS NOT CORRECT, PLEASE CHECK BACK IN A FEW DAYS... The Simple Renard RGB+W has three diagnostic LEDs.
  1. The Power LED is lit when +5vdc is available to the PIC from either the voltage regulator circuit or voltage regulator bypass, if it is installed and +5vdc is applied to TB1 (V+1).
  2. The Status LED flashes on and off when the power is applied and the PIC is properly programed and running.
Mounting in Housing
Jumper Settings / Headers
JP1 XBee Header
Pin Layout
1 = +5VDC
2 = N/C
3 = GND
4 = RX from 485 chip
5 = RX in to PIC
JP2 PIC Bypass
This header is currently unused. The default position is a jumper across pins 2/3.
Pin Layout
1 = Data In From RS485 IC
2 = Data Out to RS485 IC
3 = Data Out from PIC
JP3 ICSP
Pin Layout
Pin 1 = MCLR
Pin 2 = +5 volts
Pin 3 = GND
Pin 4 = PGD
Pin 5 = PGC
Pin 6 = PGM/RB5
Data
Outputs
J3 is Output channels 1-4
J4 is Output channels 5-8
J5 is Output channels 9-12
J6 is Output channels 13-16
J7 is Output channels 17-20
J8 is Output channels 21-24
J9 is Output channels 25-28
J10 is Output channels 29-32
Pin 1 - +5vdc
Pin 2 - First Channel Output
Pin 3 - not connected
Pin 4 - Second Channel Output
Pin 5 - not connected
Pin 6 - Third Channel Output
Pin 7 - Ground
Pin 8 - Fourth Channel Output
Power
The Simple Renard 32 Combo makes use of a different PIC then the usual PIC found in most Renard devices. The Simple Renard 32Combo does not use the default Renard firm. You must make use of the special firmware listed below to program your Simple Renard 32 Combo. The Simple Renard 32 Combo firmware only runs Renard protocol. A DMX version is not yet available.
The Simple Renard RB+W has one version of the software available.
  1. There is one version of the software that makes use of the full 32 channel.
You must modify the firmware in the .inc file to match the correct baud rate of your data network. The default baud rate is 56K.
You must modify the firmware in the .inc file if you want to use a different start address for the device. The default address is 1.
Downloads
PCB
Design Options
Interest thread
Thread 1
Thread 2
