Simple Renard RGB+W
Revision as of 01:43, 1 April 2012 by Jklingert (talk | contribs) (Mouser)
Simple Renard RGB+W Parts
PartDescriptionMouser PNQty
P1Fixed Terminal Blocks 5.08MM VERTICAL 2P wire protector571-79694922
C1,C2Aluminum Electrolytic Capacitors - Leaded 35volts 47uF 5x11 20% 2LS647-UVZ1V470MDD2
C6Multilayer Ceramic Capacitors (MLCC) - Leaded 0.33uF 50volts X7R 10%81-RDER71H334K1K103B1
D1Zener Diodes 4.3 Volt 0.5 Watt)78-1N5229B1
D2Zener Diodes 9.1 Volt 0.5 Watt)78-1N5239B1
IC1RS-485 Interface IC LP Diff Pairs595-SN65LBC179P1
IC3Linear Regulators - Standard 1A Pos Vol Reg512-LM7805CT1
IC5Microcontrollers (MCU) 32KB 1536 RAM 36I/O579-PIC18F4520-I/P1
ICSPHeaders & Wire Housings FLAT HEADER 6P Straight Post tinr571-64045261
JP2 XBee headerHeaders & Wire Housings FLAT HEADER 5P Straight Post tin571-640452-51
Shunt for XBheader and Vreg bypassHeaders & Wire Housings Mini Shunt .177" height737-MSC-G3
JP3 Vreg bypassHeaders & Wire Housings FLAT HEADER 2P Straight Post tin571-64045221
J1-J10Ethernet & Telecom Connectors 8 PCB LO PRO R/A571-5555164-110
Status LedStandard LED - Through Hole YELLOW DIFFUSED604-WP132XYD1
Power LedStandard LED - Through Hole RED DIFFUSED604-WP132XID1
RX/TX LedStandard LED - Through Hole GREEN DIFFUSED604-WP132XGD1
R1,R2,R6Carbon Film Resistors - Through Hole 1.0Kohms 0.05299-1k-RC3
R3,R7Carbon Film Resistors - Through Hole 330ohms 5%299-330-RC2
R4Carbon Film Resistors - Through Hole 10Kohms 5%299-10k-RC1
R5Carbon Film Resistors - Through Hole 120ohms 0.05299-120-RC1
R9,R10Carbon Film Resistors - Through Hole 27Kohms 5%299-27k-RC2
R11-42Carbon Film Resistors - Through Hole 820ohms 5%299-820-RC32
T1-32Transistors Bipolar (BJT) 600mA 75V NPN863-PN2222AG32
Housing
Building the Simple Renard RGB+w
  2. Install the resistors:
  3. Install the capacitors:
  4. Install the IC socket:
  5. Install the transistors:
  6. Install the light emitting diodes:
  7. Install the 5v linear regulator
  8. Inspect the board to look for any missing solder joints, solder bridges or cold solder joints.
Final Testing
Mounting in Housing
Connecting up the Simple Renard RGB+w
Pin 1 -
Pin 2 -
Pin 3 -
Pin 4 -
Pin 5 -
Pin 6 -
Pin 7 -
Pin 8 -
File:SR RGB+W sch.pdf
PCB
Design Options
