Troubleshooting Guide The Renard SS16
- This page is intended to help identify/isolate some of the common problems individuals encounter when building/operating the Renard SS16 controller board.
Basic Troubleshooting Info
Verify Setup
- Verify that the Renard SS16 is assembled correctly as compared to the Renard SS16 Controller Assembly Instructions wiki.
- Verify that you have power/control cables connected correctly as compared to the Renard SS16 Controller wiki.
- Verify that you have the Vixen plug-in settings correct as compared to the Renard SS16 Controller wiki.
Most Common Problems
- Bad data cable coming from the computer. Many individuals assume that all serial cables are identical, but that is far from the truth. Just because a cable has the correct DE9 connectors on each end doesn’t mean that the wires inside are going to the correct pins for Renard operation. It is always best to physically check the pin continuity to verify that the cable will work for Renard operation. Make sure that your interconnect cable is wired according to the Renard SS16 Controller wiki.
- Incorrect Vixen Settings. It cannot be emphasized enough, the Renard boards will not work correctly if Vixen is not setup correctly. Verify that you have the Vixen plug-in settings correct as compared to the Renard SS16 Controller wiki.
Troubleshooting the Renard SS16 Controller
Troubleshooting Flow
Troubleshooting Steps
- Verify that you have the power/control cables connected correctly as compared to the Renard SS16 Controller wiki.
 - For the following steps, the PICs (U6 & U7) need to be programmed with the Renard SS Operational Firmware.
 - Turn ON AC power
 - PWR LED should be lit
 - Run a Vixen sequence
- If they do, then your Renard SS16 Controller board is operational
 - Turn OFF AC power
 - Swap PIC chips U7 and U6
 - Turn ON AC power
- If not, reprogram or replace PIC chip U6 and retest
Symptom(s):
- PWR LED not lit
 - IC Chips hot to the touch
Possible Problem(s):
- No input voltage present
 - Transformer bad
 - Voltage Regulator bad
 - LED installed backwards
 - Blown fuse
- Remove power from Renard SS16
 - Disconnect all cables.
 - If installed, remove all 21 IC chips from their sockets (U2, U4 thru U7, and M1 thru M16).
 - Turn ON AC power.
 - Did the fuse blow?
- If it did, go to step 17
- If incorrect, go to step 13
 - Did the PWR LED light?
- If it did, go to step 21
 - Measure AC voltage between  top side of F1 and any N terminal.
 - Measure AC voltage between  bottom side of F1 and any N terminal.
 - Turn OFF AC power
 - Remove F1
 - Turn ON AC power
 - Recheck AC voltage between  bottom side of F1 and any N terminal.
 - Bad/shorted triac
 - Turn OFF AC power
 - Install one of the IC chips (U2, U4 thru U7, and M1 thru M16) into its respective socket.
 - Turn ON AC power
Symptom(s):
 - HB and ZC LED do not flash
 - FE and/or OE LEDs light
- Oscillator bad
 - Zero Cross signal bad
 - Vixen settings incorrect
 - PIC bad
- Turn OFF AC power
 - Remove PIC chip U6
 - Install a PIC programmed with the Renard SS Diagnostic Firmware into the U6 position.
 - Turn ON AC power
 - The  Renard SS Diagnostic Firmware should perform the following channel test:
 - Reflash the PIC with the Renard SS Diagnostic Firmware
 - If the problem continues, then edit the Renard SS Diagnostic Firmware to change from using the external oscillator to using the internal oscillator. If you don't know how to do this, then download this version of the Beta Renard Diagnostics Firmware.
- Replace U2
 - Check the values of R1 & R2
REMINDER:
The Renard SS16 Controller Board wiki page.
NOTE:
 - SD LED will be ON whenever Vixen sends data to the Renard SS16.  The FE and OE LEDs should remain OFF.
- If this is correct, then your Renard SS16 has passed the diagnostics test.
- Make sure that your interconnect cable is built according to the Renard SS16 Controller wiki.
 - Replace U5
- Turn OFF AC power
 - Turn ON AC power
- HB LED should light
- ZC LED should light
- SD LED should light
- FE LED should light
- OE LED should light
 - b. Remove shunt from JP3
 - d. Install shunt on JP3
 - If incorrect, replace RN1
Symptom(s):
- Bad triac
 - Bad opto
 - Bad/missed solder joints
- Turn OFF AC power
 - Are any of the triac gate resistors (R26-R41) burnt/blown/damaged?
 - Are channels 9 thru 16 bad?  If they are,
- Check the right side fuse
- If it is, go to step 22
- If not, then what are you doing at this step. Start over.
 - Turn ON AC power
 - Test lights should be OFF
- If the test lights are ON, go to step 37
- Turn OFF AC power
 - Install PIC chip U6
 - Turn OFF AC power
 - Turn OFF AC power
 - Turn ON AC power
SAFETY NOTICE:
- Bad triac
- It should be 5 VDC
 - Remove PIC chip U7
 - Turn ON AC power
- Turn OFF AC power
 - Install PIC chip U7
 - Turn OFF AC power
- Return to step 23 and repeat tests with the new opto
 - Turn OFF AC power
 - Turn ON AC power
SAFETY NOTICE:
- Bad triac
 - Turn OFF AC power
 - Remove the opto (M1-M16) controlling the bad channel
 - Turn ON AC power
 - Is the test light still ON?
