Electronics Hardware
Revision as of 10:48, 22 January 2012 by Wjohn (talk | contribs) (LedTriks)
Links
SSR Direct Attach
Kit74
Hill320
Olsen 595/Grinch
Firegod
  • Documentation: Firegod
Renard
Lynx
Helix
  • Documentation: Helix
LedTriks
Triks-C
LEDTRIKS LED PANELS
  • Connected to LEDTRIKS Controller: via CAT5 cables.
  • Documentation: LEDTRIKS Panel
PIX-C
  • Documentation: PIX-C
JEC Pixel Displays
  • Controlled through: DMX
rgbLED
Color Stick
RS485 Splitter
FM Transmitters & Antennas
Digital Input/Output Cards
