SSRez
Why Another SSR?
Lastly, the RJ45 connector could be difficult to remove with the locking pin as the pin ends up in a tight corner. A vertical RJ45 jack made this so much easier. Now, some users like the right angle connection. The great thing is that both types will fit the board. So, if you want the "Dino Option" feel free to use the right angled connector.
SSRez Features
- Designed to fit in the TA-200 Enclosure
 - Made with 2oz Copper boards for 7A total capacity
 - Trace spacing supports 240VAC use
 - RJ45 Jack layout for Top or Side Load for flexibility
 - On board 5V Logic Power LED
 - Triac layout designed with Heat Sinks in mind
 - Separate Terminals for each wire making the connections easier
 - Wiring "channel" makes the connections easier
 - Clean and Distinct Low Voltage/High Voltage Isolation
 - Fuse Position and layout allows for the Optional Fuse Cover
PLEASE NOTE: THE OVERLAY FOR THE TRIACS IS INCORRECT FOR Version 1.3. THE TAB SHOULD FACE THE BOTTOM OF THE BOARD, NOT THE TOP. Rev 1.3a is correct and is now shipping
PCB overlay V 1.3 e
This is the current version of the SSRez (1.3e) with the neon indicator.
Bill of Materials
QTY Mouser #: Description 1 571-5556416-1 Modular Jacks 8 PCB TOP ENTRY marked RJ45 1 504-GMC-7 5mm x 20mm Medium Time Delay Fuses 125VAC 7A Med Time Delay 4 511-BTA04-700T Triacs 4 Amp 700 Volt marked Q1, Q2, Q3, and Q4 2 534-3517 Fuse Clips and Holders PC FUSE CLIP 5 MM 1 604-WP7104IT LED Standard HI EFF RED TRANS marked LED 5 660-CF1/4C681J 1/4Watt Axial Leaded Carbon Film Resistors 680ohms 5% marked R5, R6, R7, R8 and R9 4 660-CF1/4C181J 1/4Watt Axial Leaded Carbon Film Resistors 180ohms 5% marked R1, R2, R3 and R4 4 859-MOC3023 Optocomponents Optocoupler TRIAC marked U1, U2, U3 and U4 4 571-1-390261-1 IC Sockets 6P ECONOMY TIN (Optional!) also marked U1, U2, U3 and U4 5 571-28228372 Terminal Blocks 5.08MM PCB MOUNT 2P 3 Screw,#8x1/2" Pan Head Sheet Metal 1 TA-200 Enclosure 1 Male Plug Power Cord, Rated for 8A Minimum 4 Female Plug Power Cord, Rated for 4A Minimum 1 534-3527C Fuse Cover (Optional) 1 TBD Resistor, 1/4W, 100kOhm (Optional for Revision 2.0 Boards) 1 TBD AC Indicator Lamp (Optional for Revision 2.0 Boards)
Now the above is the base Bill of Materials for 120VAC operation.  There are, however, some options that can be handled.  These are listed below.
240VAC Operation
FireGod
If the SSRez is going to be used with a FireGod system, Resistors R5-R8 may need to be changed. If the channel LEDs are used on the field modules AND the interface board voltage regulator is 5VDC, replace R5, R6, R7, R8, and R9 with 510 Ohm Resistors. You must also use the "Sinking Code" in the FireGod Field Modules when using the SSRez.
15. Install the fuse.
Wiring The SSRez
Heat Sink
Template Coming Soon
Troubleshooting
'This section is under construction...please do not use for the time being....
Symptom(s):
Possible Problem(s):
- Bad triac
 - Triac in Backwards
 - Bad opto
 - Opto/MOC in Backwards
 - Bad/missed Solder Joints
Troubleshooting Flow
Troubleshooting Steps
- Turn OFF AC power
 - Are any of the triac gate resistors (R1-R4) burnt/blown/damaged?
- If so, replace that resistor and check the solder pads on the associated TRIAC. Blown gate resistors are usually caused by a missed solder connection on the TRIAC.
 - Remove the PIC from the controller for this channel.
 - Connect power to the H and N terminal blocks
 - Turn ON AC power
 - Test lights should be OFF
- If the test lights are ON, go to step <XX>
- Test lights should come ON when the jumper is connected to the locations in the table. Now this table has eight tests as they are the 8 channels from a single PIC Microcontroller. However, the SSRez has only 4 channels. The channels in the chart for 5-8 are for a different SSRez.
Controller
ChannelOptoisolator Test Lights
at SSRezConnect Jumper Wires between 1 U1 Channel 1 2 U2 Channel 2 3 U3 Channel 3 4 U4 Channel 4 5 U1 Channel 1 6 U2 Channel 2 7 U3 Channel 3 8 U4 Channel 4
- Turn OFF AC power
 - Install PIC back into the controller
 - Turn OFF AC power
 - Replace the opto (U1-U4) controlling the bad channel
 - Turn OFF AC power
 - Remove the opto (U1-U4) controlling the bad channel
 - Turn ON AC power
SAFETY NOTICE:
- Bad triac
- It should be 5 VDC
- If incorrect, check the current limiting resistor (R5-R8) associated with that opto. You should be able to read approx 5 VDC on both sides of the resistor.
 - Turn OFF AC power
 - Turn ON AC power
 - Is the test light still ON?
Early Prototype Picture
