LEDancer
The information on this page is out-of-date due to some changes on the coop LED-strip PCB.
General
The LEDancer (Le Dancer) is an inexpensive controller for up to 56 LEDs with a DMX512 input interface. The LEDs are connected together in a Charlie-Plexed common-cathode configuration. The design needs to use 2N3906 booster transistors for the LED cathodes to ensure that the low-level drive of the PIC is not exceeded, a configuration sometimes called chipi-plexing. The DMX address of the controller can be changed by shunting one of the PIC pins to ground and then sending a specially formatted DMX packet with the desires address.
PCB Schematic
PCB Design
At the moment there isn't a released PCB design. The design consists of a controller board (with a PIC16F1826 and a ST485 RS485 receiver, a jumper for enabling the DMX Address Program Mode, eight resistors and 8 2N3906 transistors, and some connectors.
Here is a proposed sample PCB design:
Connector Pinout
Jumper Identification
LED Connections
Wirelist
Stackable LED Board Design
PIC Program
Programming the DMX Address
