Vastelec FM02
The FM02 is a two board FM transmitter.  It accepts a stereo audio source and outputs a stereo FM broadcast signal on the frequency shown on the LED display.  It comes just as shown in the picture above.
- Power. A regulated 12v DC power supply is needed. 100ma is enough current.
About VAST Electronics
DO NOT apply anything GREATER then REGULATED 9V-16V DC to your unit. If you aren't sure, then ask for help in the forums. Use a meter to check the voltage first. If all you have is a wall-wart that is labeled 12V, then that is most likely NOT regulated. A simple test of the output voltage with a meter will tell the tale. I use one of the voltage regulators from Sure Electronics with my unit (Part number:PS-SP12113). These are about $5 online.
When you connect power to the FM02 it is VERY important that you get your positive(+) and your negative(-) correct. If you hook up the power incorrectly, you can easily damage/ruin the unit.
Do you have a HUM ?
Audio
Detailed Board Dimensions
Antenna
 You will need to buy or make an antenna.  There are MANY different designs for antennas.  A large number of DIYers have made a type of antenna known as a dipole.  This is an easy to make antenna that will serve almost anyone's needs.  Here is a link to a pdf with instructions to make your own:
How to Make a Dipole Antenna
What Frequency to Use
RDS hookup information
Why you should care about the power of your transmitter
PART15:
