Vastelec FM02
Revision as of 15:06, 30 September 2011 by Ukewarrior (talk | contribs) (Antenna)
FM-02
FM-02b
FM-02b
About VAST Electronics
Vendor's Website
Data Sheet
Detailed Board Dimensions
board dims
board dims
board dims 2
board dims 2
Antenna
smatobnc
smatobnc
You will need to buy or make an antenna. There are MANY different designs for antennas. A large number of DIYers have made a type of antenna known as a dipole. This is an easy to make antenna that will serve almost anyone's needs. Here is a link to a pdf with instructions to make your own: How to Make a Dipole Antenna
What Frequency to Use
http://www.radio-locator.com/
Where can I get one of these wonderful devices ?
