Vastelec FM02
Revision as of 14:30, 29 September 2011 by Ukewarrior (talk | contribs) (Antenna)
FM-02
FM-02
The FM02 is a two board FM transmitter. It accepts a stereo audio source and outputs a stereo FM broadcast signal on the frequency shown on the LED display. It comes just as shown in the picture shown above.
About VAST Electronics
Vendor's Website
Data Sheet
Detailed Board Dimensions
board dims
board dims
board dims 2
board dims 2
Antenna
smatobnc
smatobnc
Setup
http://www.radio-locator.com/
Where can I get one of these wonderful devices ?
They may also be available at WLC ventures.
They have also been seen for sale on ebay.
