Vastelec FM02
Revision as of 02:53, 29 September 2011 by Ukewarrior (talk | contribs) (About)
FM-02
FM-02
The FM02 is a two board FM transmitter. However, it is not a complete unit ready for use. Instead, it bridges the gap between an out-of-the-box solution, and a build-your-own unit that starts with a bare PCB and a bag of parts.
About VAST Electronics
Vendor's Website
Data Sheet
Do NOT power it up without an antenna. You don't need to have your 'real' antenna ready for this. You can put the adapter on and then stick a 12" piece of wire into the center of the BNC connector. This will dissipate the RF energy just fine. Just be sure you don't enlarge the hole inside the BNC. DO NOT apply anything GREATER then REGULATED 12V DC to your unit. If you aren't sure, then ask for help in the forums. Use a meter to check the voltage first. If all you have is a wall-wart that is labeled 12V, then that is most likely NOT regulated. A simple test of the output voltage with a meter will tell the tale. I use one of the voltage regulators from Sure Electronics with my unit. These are about $5 online.
Detailed Board Dimensions
board dims
board dims
This is one board of a two board set
This is One board of a two board set. ==
Antenna
Setup
http://www.radio-locator.com/
