SSRneon
- the images shown of the board layout will be replaced with pictures of the actual PCB
 - once the boards from the first coop have been received.
Safety Features
The main safety feature of any SSR is the main FUSE. This is discussed in a separate section below.
The SSRneon contains two NE-2E neon light bulbs. These lights are what differentiates the SSRneon from the other available SSRs.
Home Etch
The copper image can be found here: <file to come>
The silkscreen image can be found here: <file to come>
The image of the product board can be found here: <file to come>
Fuse Rating
Various fuse values have been listed for all the various 4 port SSRs. e.g. Sean Bowf, SSRoz, SSRez.
BOM for 120VAC Operation:
4      571-1-390261-1     IC Sockets 6P ECONOMY TIN  (Optional, but worth every penny)
                          also marked U1, U2, U3 and U4
5      571-28228372       Terminal Blocks 5.08MM PCB MOUNT 2P
See above for TA-200 sources.
240VAC Operation
FireGod
Once the production boards have arrived, this section will be populated.
Wiring The SSRneon
The following image shows how to connect wires to the SSRneon.
- Picture to be inserted once boards are received.
Original SSRneon
The original SSRneon was not designed for any particular enclosure. It has only one neon bulb to signal the presence of AC before it passes through the fuse. You must also wire a 100K resistor inline with the single neon bulb leads because there is no separate attachment point for the resistor.
