Ren48LSD
Revision as of 02:05, 24 July 2010 by Budude (talk | contribs) (FAQ)
Ren48LSD Construction Manual
What is the Ren48LSD?
The strips require up to 360mA per output (18 LEDs x 20mA) so I used an NPN bipolar transistor to drive them. The transistors support up to 600mA so there's plenty of headroom left. The transistors are fairly cheap so it makes for a simple, inexpensive solution. The controller design used the Ren24SS as a base, using the same PIC, clocking and serial interface configuration but expanded to 6 PICs to support 48 channels or driving up to 12 strips per board. Because of this, the controller supports standard Renard protocol FW using RS-232/485 as well as the DMX version. The board requires either a 5vdc well regulated supply or a good 9- 12vdc supply. The input supply also drives the LED strips.
Ren48LSD Parts
Mouser BOM
Mouser PNDescriptionQty
579-PIC16F688-I/PMicrocontrollers (MCU) 7KB 256 RAM 12 I/O6
571-1-390261-3IC & Component Sockets 14P ECONOMY TIN6
863-MPS2222AGBipolar Transistors 600mA 75V NPN48
511-L7805CVLinear Regulators - Standard 5.0V 1.0A Positive1
604-WP7104ITStandard LED - Through Hole HI EFF RED TRANS1
80-C322C104K5RMultilayer Ceramic Capacitors (MLCC) - Leaded 50volts 0.1uF 10%10
299-1K-RCCarbon Film Resistors 1.0Kohms2
299-470-RCCarbon Film Resistors 470ohms48
299-10K-RCCarbon Film Resistors 10Kohms6
571-5520251-4Telecom & Ethernet Connectors 8/8 SIDE ENTRY14
571-7969492Terminal Blocks 5.08MM VERTICAL 2P wire protector2
Building the Ren48LSD
  6. Install the 1N5229 diode near the 485 chips – note the correct orientation
  7. Install the 1N5239 diode near the 485 chips – note the correct orientation
  1. Install all forty-eight 470 ohm resistors doing 4-8 at a time.
  1. Install the six 14-pin PIC chip sockets - note the correct orientation (top 3 go one way, bottom 3 go the other way)
  2. Install the two 8-pin 485 chip sockets - note the correct orientaiton
  1. Install the 18.432MHz oscillator – note the squared corner for correct orientation
  2. Install the ten decoupling capacitors near the IC sockets, oscillator and regulator
  1. Install the 48 transistors – note the correct orientation – the emitter is nearest the PICs, base in the middle and collector near the RJ45 jacks
  1. Install the two 2-pin shunt jumpers (note picture shows only one installed)
  2. Install the LED – note correct orientation
  3. Install the DC input terminal blocks – note correct orientation
  4. Install the 5v regulator (OPTIONAL) - the back goes towards the edge of the board
  5. Install the large capacitor – note correct orientation
  1. If you are not using the 5v regulator then you need to install a jumper across the input/output of where the regulator goes. A 1/2W resistor lead is good for this but any 18-20 gauge wire is fine.
  1. Install the fourteen RJ45 jacks – note that top-entry jacks can be subsituted
  2. Mount the 5v regulator heat sink if you installed the regulator – use a small amount of heat sink compound
Initial Testing
Renard Protocol
Make the following changes:
Renard-DMX Protocol
Obtain the standard Renard firmware from here:
#define DMX_START_ADDRESS 1
Final Testing
  1. Common +DC
  2. Red Ground
  3. Common +DC
  4. Blue Ground
  5. Common +DC
  6. Green Ground
  7. Common +DC
  8. White Ground
Q1: Can this use 24vdc?
A1: The board was not designed to use 24vdc – however it may be possible but requires some hacking to work. The issue is with the 5v regulator that it will get very hot at 24vdc input even with a heat sink. One option would be to install a resistor between the +DC input and the input leg of the regulator of sufficient size/wattage to drop the input voltage to the regulator to keep it cooler. This is similar to what is done with the Ren24LV. I have not tested this myself but with a bit of expermentation, should not be hard to determine. Since the current draw is much higher with this (post regulator) than the 24LV and it won't be the same value.
[UPDATE] Unfortunately, even 12vdc appears to be a bit too much for the existing 5v regulator when all channels are enabled. I am working on a fix to support both 12v and 24v operation. (as of 7/15/10)
Q2: What if I only have 6 strips?
A2: Well - you're in luck! Next to PIC #3 and PIC #6 is a via hole that will bypass PICs #4 - #6 if you install a wire between them. Note that this is only necessary if you are planning to daisy-chain another board from this one. This effectively makes this a Ren24LSD. If you are not going to daisy-chain another board, you can leave it off as well as the RS-485 output chip. Personally, I think this is false economy since you'll have to dig the parts up if you change your mind and want to run a board off this one. In either case, you certainly save time and money by not installing the PICs, sockets, transistors, resistors and output connectors for strips 7-12 if you don't have them.
Q3: What the heck is that "GAB DMX-THRU" connector for?
A3: This was an attempt to support DMX-THRU so that you can run additional DMX devices from an external RJ45 or XLR connector. "GAB" stands for "Ground", "Data-A" and "Data-B" for the RS-485 interface for DMX. This has not been tested at all yet so it may or may not work at this time. If you do try it and it works, please let me know and we can udpate this entry to show it works OK.
Q4: Can I use standard DIY SSRs with the Ren48LSD?
A4: Maybe - but with the following caveats:
  • It has not been tested at all
  • The power LED on the SSR will not work as there is no ground fed to pin 7.
  • To be safe, pins 3, 5 and 7 should not be connected from the Ren48LSD to the SSR.
  • You MUST use a 5vdc source only - using a higher voltage (say 12v) could (probably will) damage the optos on the SSRs (AC or DC).
For these reasons, it is not really recommended to use an SSR on the Ren48LSD.
<PDF Version removed as it was downlevel>
