Part Substitutions
Revision as of 18:37, 25 September 2009 by Fkostyun (talk | contribs) (Other)
This page is intended to provide members with a resource to see what parts are interchangeable between the various DIYC boards.
This page is by no means the “gospel” of what parts can or cannot be interchanged.
IC Chips
PART NUMBER
(Mouser PN# unless noted)
NOMENCLATURE POSSIBLE SUBSTITUTE PARTS SYSTEMS USED ON
SN65LBC176AP Differential Bus Transceivers SN65LBC176PE4
511-ST485BN
595-SN65176BP
Renard 16
Renard 24
Renard 64
Renard SS
579-PIC16F688-I/P PIC Microcontroller 579-PIC16F688-E/P Renard 16
Renard 24
Renard 64
Renard SS
782-H11AA1 Optocoupler, Bi-Directional Input   Renard 16
Renard 24
Renard SS
859-MOC3023 Optoisolator, Triac Driver   Renard 16
Renard 24
Renard SS
571-1-390261-2 IC Socket, 8 pin (for U1 & U2) 575-193308 Renard 16
Renard 24
Renard 64
Renard SS
571-1-390261-3 IC Socket, 14 pin (for U3–U5) 575-199314 Renard 16
Renard 24
Renard 64
Renard SS
571-1-390261-1 IC Socket, 6 pin (for U8–U31)   Renard 16
Renard 24
Renard 64
Renard SS
Voltage Regulators
PART NUMBER
821-TS7805CZ 5VDC Voltage Regulator 511-L7805CV Renard 16
Renard 24
511-L4940V5 Regulator, LDO, 5V, 1.5A   Renard 64
511-LF50CV Regulator, LDO, 5V, .5A   Renard SS
532-574502B00 Heatsink for Voltage Regulator   Renard 16
532-577102B00 Heatsink for Voltage Regulator   Renard SS
532-7136DG Heatsink for Voltage Regulator   Renard 24
Diodes, LEDs, Triacs
PART NUMBER
78-1N5239B Diode, Zener 9.1V .5W   Renard 16
Renard 24
Renard 64
Renard SS
78-1N5229B Diode, Zener 4.3V .5W 512-1N5229B_T50A Renard 16
Renard 24
Renard 64
Renard SS
604-WP63ID LED, 5mm Red Any standard 5mm LED will work as a replacement Renard 24
604-WP1503GD LED, 5mm Green Any standard 5mm LED will work as a replacement Renard 24
604-WP7104EC LED, 3mm Red Any standard 3mm LED will work as a replacement Renard 16
604-WP7104IT LED, 3mm Red Any standard 3mm LED will work as a replacement Renard SS
604-WP7104GT LED, 3mm Green Any standard 3mm LED will work as a replacement Renard 16
Renard 64
Renard SS
859-LTL-403G LED, Rectangular, Green 859-LTL-403HR - Red
859-LTL-403Y - Yellow
Renard 64
625-1N4001-E3 Diode   Renard 16
Renard 24
625-1N5817-E3 Schottky Diode (20V, 1A)   Renard 64
Renard SS
821-DB102G Bridge Rectifier, 1A 100V   Renard 24
511-BTA08-400B Triac, 8A 400V 511-BTA04-700T
Triac, 4A 700V
(alternative Triac for use with LED light strands)
Renard 16
Renard 24
511-BTA04-700T Triac, 4A 700V   Renard SS
Resistors
As a general “rule of thumb” for DIYC projects, you can substitute any resistor of equal value that also has a power rating equal to/or greater for any of the following resistors. The material that the resistor is made of (ie: carbon film or metal film) is not a critical factor for DIYC projects.
PART NUMBER
291-120-RC Resistor, Carbon Film 120 ohms 1/4W 5% 271-120-RC
660-MF1/4DCT52R1200F
Renard 16
Renard 24
Renard 64
Renard SS
291-1K-RC Resistor, Carbon Film 1K ohms 1/4W 5% 271-1K-RC
660-MF1/4DC1001F
(Renard 24 ZC resistors)
Renard 24
299-1K-RC Resistor, Carbon Film 1K ohms 1/8W 5% 271-1K-RC
660-MF1/4DC1001F
(Incoming data circuit resistors only)
Renard 16
Renard 24
Renard 64
Renard SS
299-27K-RC Resistor, Carbon Film 27K ohms 1/8W 5% 271-27K-RC
660-MF1/4DLT52R2702F
Renard 16
Renard 24
Renard 64
Renard SS
291-680-RC Resistor, Carbon Film 680 ohms 1/4W 5% 271-680-RC Renard 24
299-680-RC Resistor, Carbon Film 680 ohms 1/8W 5%   Renard 64
Renard SS
291-180-RC Resistor, Carbon Film 180 ohms 1/4W 5% 271-180-RC
273-180-RC
Renard 16
Renard 24
Renard SS
71-CCF60-15K-E3 Resistor, Metal Film 15K ohms 3/4W 1%   Renard 16
291-750-RC Resistor, Carbon Film 750 ohms 1/4W 5%   Renard SS
299-750-RC Resistor, Carbon Film 750 ohms 1/8W 5%   Renard 64
299-330-RC Resistor, Carbon Film 330 ohms 1/8W 5%   Renard 64
266-680 Resistor Network, 10 pin, 680ohms 2%   Renard 16
264-330 Resistor Network, 6 pin, 330ohms 2%   Renard SS
652-4608X-1LF-680 Resistor Network, 8 pin, 680ohms, Bussed 2%   Renard 64
Capacitors
PART NUMBER
81-RPEE41H105M4K1E12 Capacitor, Monolithic Radial Lead 50V 1uF   Renard 16
80-C410C104M5U Capacitor, Axial Ceramic 50V 0.1uF   Renard 16
581-SA105E104MAR Capacitor, Axial Ceramic 50V 0.1uF   Renard 24
140-HTRL25V10-RC Capacitor, Electrolytic 25V 10uF 105°C   Renard 24
140-XRL25V1.0-RC Capacitor, Electrolytic 25V 1uF 85°C   Renard 24
140-XRL16V6800-RC Capacitor, Electrolytic 16V 6800uF 85°C   Renard 64
140-XRL16V2200-RC Capacitor, Electrolytic 16V 2200uF 85°C   Renard SS
80-C322C104K5R Capacitor, Radial Ceramic 50V 0.1uF   Renard 64
Renard SS
140-XRL16V47-RC Capacitor, Electrolytic 16V 47uF 85°C 140-XRL16V47-RC-TB Renard 64
Renard SS
Other
PART NUMBER
838-3FD-316|Transformer, Dual Primary/Secondary   Renard 24
838-3FS-312 Transformer, Single Primary/Dual Secondary   Renard SS
520-TCF1843-X Crystal Clock Oscillator, 18.432 MHz (full size)   Renard 24
520-TCH1843-X Crystal Clock Oscillator, 18.432 MHz (half size) ACH-18.432MHZ-EK Renard 16
Renard 64
Renard SS
538-22-03-2021 Header, 2-Pin PCB 538-22-28-4360
Header, 36 Pin Breakaway
(used to make smaller headers)
Renard 16
Renard 64
Renard SS
538-22-03-2031 Header, 3-Pin PCB Renard 24
151-8000 Shunt 571-3828115 Renard 16
Renard 24
Renard 64
Renard SS
504-GMA-10 Fuse, Fast Acting 10A 125VAC   Renard SS
504-GMA-15 Fuse, Fast Acting 15A 125VAC   Renard 16
Renard 24
504-1A3399-10 Holder, Fuse Clip PCB mount 5mm   Renard 16
534-3517 Holder, Fuse Clip PCB mount 5mm   Renard 24
Renard SS
534-3527C Cover, Fuse Clip   Renard SS
571-5556416-1 Jack, Modular RJ45 PCB Mount Top Entry 571-5564161 Renard 24
Renard 64
Renard SS
571-5520251-4 Jack, Modular RJ45 PCB Mount Side Entry   Renard 16
Renard 64
636-182-009-213R531 Connector, D-Sub Female, Rt Angle PCB mount, DE9`   Renard 64
152-3409 Connector, D-Sub Female, Rt Angle PCB mount, DE9`   Renard SS
538-39890-0302 Terminal Block, 2 Pos 5.0 mm   Renard 16
571-2828372 Terminal Block, 2 Pos 5.08 mm   Renard SS
571-7969492 Terminal Block, 2 Pos   Renard SS
571-7969494 Terminal Block, 4 Pos (Input Power)   Renard 24
571-2828376 Terminal, 6 Pos   Renard 24
Opt#1
651-1725041 Terminal, Dbl Stack 4 Pos   Renard 24
Opt#1
534-1287 Terminal, Spade   Renard 24
Opt#2
534-4902 Male Sturdi-mount Terminal   Renard 64
159-2215 Vinyl Insulated Couplers (Female)   Renard 64
