Electronics Hardware
Revision as of 14:22, 23 March 2009 by Wvengineer (talk | contribs) (Links)
Links
SSR Direct Attach
Kit74
Hill320
Olsen 595/Grinch
Firegod
  • Documentation: Firegod
Renard
  • Documentation: Renard
Lynx
Ledtriks
Tricks-c
  • Controlled through: Serial port or standalone
  • Documentation: [TBA]
This is a an add on controller/process for the Ledtricks. One of the problems with the original LEDTRIKS design was the load placed on the PC to chunk the data out the parallel port. The TRICKS-C uses a ATMEL process to take a LEDSTRIKS file and send it out to the LEDTRIKS Controller, via the serial prot.
JEC Pixel Displays
  • Controlled through: DMX
rgbLED
TBA
Digital Input/Output Cards
