Serial, RS232
Voltages
| Level | Transmitter capable (V)  | Receiver capable (V)  |
| Space state (0) | +5 ... +15 | +3 ... +25 |
| Mark state (1) | -5 ... -15 | -3 ... -25 |
| Undefined | - | -3 ... +3 |
Achievable distances
The maximum distance that RS323 can go varies depending on Bit Rate and also the capacitance of the wire itself. Texas Instruments states that RS 232 maximum cable length is 50 feet, or the cable length equal to a capacitance of 2500 pF. Depending on the cable such as Category 5 Twisted pair the maximum achievable distance at 19200 is 157 feet.
here is a quick chart showing theoretical limits as various data rates
| Baud rate | Maximum cable length (ft) |
| 19200 | 50 |
| 9600 | 500 |
| 4800 | 1000 |
| 2400 | 3000 |
