Serial, RS232
Voltages
| Level | Transmitter capable (V)  | Receiver capable (V)  |
| Space state (0) | +5 ... +15 | +3 ... +25 |
| Mark state (1) | -5 ... -15 | -3 ... -25 |
| Undefined | - | -3 ... +3 |
Achievable distances
| Baud rate | Maximum cable length (ft) |
| 19200 | 50 |
| 9600 | 500 |
| 4800 | 1000 |
| 2400 | 3000 |
