Electronics Hardware
Revision as of 19:56, 26 April 2008 by Firegod (talk | contribs) (Firegod)
Links
SSR Direct Attach
Kit74
Hill320
Olsen 595/Grinch
Firegod
The overal archecture of the system looka like this:
Renard
  • Documentation: Renard
Lynx
Ledtriks
JEC Pixel Displays
  • Controlled through: DMX
rgbLED
TBA
