10' Megatree
Revision as of 04:59, 22 April 2020 by Rlbrinkman (talk | contribs) (Installation)
Materials and Tools
  • 10 foot long 1½ inch EMT pipe
  • T-post
  • T-post driver, or better yet, use Sleeves for installation
  • 12½ feet of ½ inch polyethylene drip irrigation distribution tubing
  • Polyethylene drip irrigation coupling
  • 4 inch x 4 inch piece of scrap wood or plywood, about ¾ inch thick
  • Good quality outdoor penetrating paint
  • Two 12 inch pieces of 1 inch PVC pipe
  • Two 1 inch PVC pipe couplings* (cheaper) or PVC caps
  • Eight hard wall plastic hooks
  • Sharpie® permanent marker
  • Eight strings of 100-count Christmas lights, 20+ feet lighted length
  • A booklet of Ideal® or Klein® Tools adhesive wire markers
  • Three pieces of 12 inch long back-to-back Velcro® strips
  • rocks, pavers, stepping stones, or other suitable weights
  • = You may want to put something such as a star on the top of the Megatree. If so, choose a coupling that slip fits onto the 1 inch PVC pipe on one end, and is threaded on the other end for attaching the decoration.
Construction
Hook assembly with wires attached
Tie the light strings to the EMT pipe with Velcro® strips in about three places, to contain the tangle of wires.
Installation
Place the EMT pipe (with light strings attached) over the T-post; the Megatree should remain comfortably self-standing.
  • Installing Megatree EMT pipe onto post
  • Anchored Megatree. Stepping stones hold the tubing/strings in place. Control box is under the plastic tub.
  • Four Megatrees in my yard
Taking it down
Being careful not to step on light bulbs on the ground, tie the light strings to the EMT pipe with Velcro® strips in 3-4 places, to contain the tangle of wires.
Lift the EMT pipe with light strings attached off of the T-post, remove the decoration from the top of the display if applicable/desired.
Storage
Store your T-post and irrigation tubing ring as you have planned.
Here's a simple and compact way to store your Megatree(s).
