ESPixel Stick & ESPixel Pops
What is a Pixel Stick?
These controllers have two basic characteristics:
Click Here:
Pixel Pops & Pixel Pops Tiny
Pops-O-Matic Info
Order your own boards
If ukewarrior is out of boards, you can order them in groups of 3 from OSHPark: Click here for the Ordering link at OSHPark to order your own boards
These are available for a total of 34 cents from Tayda Electronics.
Fuse Holder
5A Fuse
Click Here:
The BOM's are:
Mouser BOM is in Post #35
Arrow BOM is in Post #48
Digikey BOM is in Post #49
BOM UPDATE:
DIYC member mattd has done some research and created a BOM with some alternate manufacturers.
Wiring The ESPixel Pops
A Key Point Regarding Power
A 3D printed Mount for your Pixel Pops controller
A small Mount that you can mount in a cable guard box or other waterproof enclosure
The .stl file is available for free on thingaverse at this link:
Thingaverse link for Pixel Pops mount
Programming the ESP-01 Module
As of 11/21/2019, the current release by Shelby that implements dimming control and other features.
As of 1/14/2020 Version 3.1 is a Major Update Many features including direct support of Webmos & NodeMCU ESP modules.
You can find it here: https://github.com/forkineye/ESPixelStick/releases Pixel Stick Software]
Upload the firmware
Download the latest Firmware.
Install Java JRE.
William Napier crated these in a few hours as a novice solderer. All worked fine on the first try !
