Revision as of 18:32, 9 January 2018 by Dmoore (talk | contribs) (HolidayCoro)
  • Pixel Controllers
  • Dumb RGB Controllers.
  • Renard (using either RS232-serial or RS485)
  • E1.31 (DMX over Ethernet)
  • DMX A traditional stage lighting protocol
  • Programs stored on SD memory cards
  • Lightorama LOR compatable gear
  • Communications Protocol (E1.31, Renard, DMX, LOR, Etc.)
  • Pixel Voltage (5VDC vs 12VDC)
  • Pixel Type (WS2801, WS2811, GECE, LOR, Etc.)
  • Number of Pixels to be Controlled
  • Number of Connectors and Number of Strings that can be Physically Connected
  • Advanced Features
    • Grouping (ability to treat multiple Pixels as one)
    • RGB Ordering (ability to correct the physical RGB order to match the software sequence order)
    • ZigZag (Ability to treat physical strings as multiple logical strings)
    • Reverse order (ability to reorder the channels on a string so the most distant one is the first channel)
    • Etc.
PIXEL CONTROLLERS
ESP-01 Based Pixel Controllers
ESPixel Stick & ESPixel Pops
The ESPixel Stick was developed by DIYC member Bill Porter aka... madsci1016. It took advantage of the amazing ESP-01 microcontroller which combines a full micro controller with a built in wifi interface all on a small form factor board with an incredibly low price. (~$2). The ESP-01 when combined with a circuit board with a small number of components creates a full function wireless pixel controller for about $10 that can control 4 universes or nearly 700 pixels. There are several variations of these controllers which are generally referred to as Pixel Sticks.
Renard PX1 Pixel Controller
Open Lighting Architecture
OLA can be used on a Raspberry Pi, Beagle Bone Black or other single board computers with SPI. It can receive E1.31 (and many other protocols) and use the data to drive SPI pixels. See https://wiki.openlighting.org/index.php/OLA_LED_Pixels for more information. The maximum pixel count is determined by the hardware and the pixel clock speed. Demo Video.
HolidayCoro
Firmware Update Page
Default IP Address is 192.168.0.50 (configurable via LCD interface or webpage) or can be configured for DHCP.
Model Max Pixels DMX Universes Pixels Supported Output Connectors String Outputs Image Link Setup Videos Note
AlphaPix 4
V3
2,720 16 UniCast (E1.31 & Artnet) WS2811,WS2812,WS801,WS2803
TM1804,TM1803,TM1812,SM16715
TLS3001,TLS3002,CY3005
LPD6803,D705,LPD1101
4 Fused Outputs
Screw Terminals
4 Outputs
680 Pixels Per Output
Bare Controller
Ready2Run with PSU, Enclosure, Cables
Demo Video
Setup Videos
Includes one dedicated RS-485/DMX output (does not use a pixel output), 28A per Controller/7.5A per Output, LCD Display for Configuration and Testing, WEB Interface for configuration and monitoring, Adapter mounting plates for CG1500 enclosure available, built-in voltage and temperature sensor allow remote controller monitoring along with the built-in fan controller for cooling the enclosure.
AlphaPix 16
V3
5,440 32 UniCast (E1.31 & Artnet) WS2811,WS2812,WS801,WS2803
16 Fused Outputs
Screw Terminals
16 Outputs
340 Pixels Per Output
Bare Controller
Demo Video
Setup Videos
Includes three dedicated RS-485/DMX outputs (does not use a pixel output), 30A per Bank, 2 Banks per Controller (60A Total)/5A per Output (80A at 20% Duty Cycle), LCD Display for Configuration and Testing, WEB Interface for configuration and monitoring, Adapter mounting plates for CG1500 enclosure available, built-in voltage and temperature sensor allow remote controller monitoring along with the built-in fan controller for cooling the enclosure. Resistor bank for outputs to reduce likely hood of shorting upon incorrect connections.
Advatek Lighting Pty Ltd
(Australia Based run by DIYC user Unknown (Devo))
PixLite 4 2,720 16 UniCast
16 MultiCast
USC6909,UCS6912,SM16716,MBI6020
4 Fused Outputs
Screw Terminals
4 Outputs
MFG Product Link
US Re-Seller Link
Assembled $119.95
Manual
Includes one dedicated RS-485/DMX output, 28A per Controller/7A per Output, Gamma Correction, Temp & Power Monitor
PixLite 16 5,440 32 UniCast
32 MultiCast
16 Fused Outputs
Screw Terminals
16 Outputs
MFG Product Link
US Re-Seller Link
Assembled $199.95
Manual
Includes four dedicated RS-485/DMX outputs (does not use a pixel output), 30A per Bank, 2 Banks per Controller (60A Total)/4A per Output, Gamma Correction, Temp & Power Monitor
SanDevices
E68x Configuration Guide
Firmware Updates
Model Max Pixels DMX Universes Pixels Supported Output Connectors Max Channels DMX Universes per Output Image Link Price Manual Note
E6804-4 2040 7Multicast / 12Unicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 4 Fused (1x4 Electrical, 4x1 Logical) 6120 Up to 12 link Assembled/Tested: $99, Full Kit: Price $69 Presale Owner's Assembly Size is 2.5" x 4", mounting holes on 2"x3" centers, compatible with CG series enclosures. Announcement
PS-1 1020 6Multicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 3060 Up to 6 link Turnkey System: $399 Owner's Assembled E682 with power supply in an Enclosure
E682-12 2040 6Multicast / 12Unicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 6120 Up to 12 link Assembled/Tested: $180, Full Kit: Price $109 Owner's Assembly To be released shortly
E682-6 1020 6Multicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 3060 Up to 6 link Assembled/Tested: $180, Full Kit: Price $109 Owner's Assembly Original E682, Before Firmware Upgrade
E681-12 2040 6Multicast / 12Unicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 6120 Up to 12 link No Longer Available Owner's Assembly Firmware To be released shortly, requires UP1 upgrade
E681-6 1020 6Multicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 3060 Up to 6 link No Longer Available Owner's Assembly Original E681, with Firmware Upgrade and UP1 upgrade
E681-4 680 4Multicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 2040 Up to 4 link No Longer Available Owner's Assembly Original E681, without Firmware Upgrade and without UP1 upgrade
E680-12 2040 6Multicast / 12Unicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 6120 Up to 12 link Partial Kit: $19 (PC Board + EEPROM) needs additional parts to function Owner's Assembly To be released shortly, requires UP1 upgrade
E680-6 1020 6Multicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 3060 Up to 6 link Partial Kit: $19 (PC Board + EEPROM) needs additional parts to function Owner's Assembly Original E680, with Firmware Upgrade and UP1 upgrade
E680-4 680 4Multicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 2040 Up to 4 link Partial Kit: $19 (PC Board + EEPROM) needs additional parts to function Owner's Assembly Original E680, without Firmware Upgrade and without UP1 upgrade
PixelController.com (Falcon Christmas)
Store
Default IP Address is 192.168.1.50. Can be configured via OLED interface or webpage. Supports DHCP (Dynamic Host Configuration Protocol).
Model Max Pixels DMX Universes Pixels Supported Output Connectors String Outputs Image Link Price Note
F16V2 10,880 64 Multicast/Unicast (E1.31) WS2811,WS2812,WS801,WS2803
GECE
16/32 Fused Outputs
Screw Terminals
16/32 Outputs
680 Pixels Per Output (340 when in 32 port mode)
Store Assembled $200.00 5-32V DC, Every port can be a different type. Expandable to 32 ports, soon to be 48 ports. Virtual string support. 40Hz refresh rate on outputs even when pixel count is 680 pixels. Includes four dedicated RS-485/DMX outputs, 30A per Bank, 2 Banks per Controller (60A Total)/5A per Output, OLED Display for Configuration and Testing, Webpage Interface, Mounting plate for CG1500 enclosure available. Voltage and temperature sensors. OLED E131 diagnostic tools. 4 - Renard (Speed and stop bits configurable), DMX and Pixelnet Outputs.
Joshua 1 Systems (J1SYS)
Setup Video
Unofficial Users Manual
ECG-P12R 2040 12Unicast LPD6803, WS2801, WS2811, TM180x, TLS3001 12 Fused (2x6 Electrical, 3x4 Logical) 6120 1 link Assembled Board: $175 Owner's Notes
ECG-PIXAD8 1360 8Unicast LPD6803, WS2801, WS2811, TM180x, TLS3001 8 Fused (2x4 Electrical, 2x4 Logical) 4080 1 link Assembled Board: $155 Owner's
ECG-P2 1360 8Unicast LPD6803, WS2801, WS2811, TM180x, TLS3001 2 Unfused (2x1 Electrical, 2x1 Logical) 4080 4 link Assembled Board: $75, Assembled Board w/case: $85 Owner's
DMX512 / ESTA 1.11 (RS485) to SPI
HolidayCoro
Model Max Pixels DMX Channels Pixels Supported Output Connectors Image Link Price Note
EasyPix V2 170 512 WS2811,WS2812,WS801,WS2803
LPD6803
1 Fused Output
Screw Terminals
Product Link $39.99 Null pixels, Reverse order,Push button setting with back-lit LCD screen, built-in sequences, replaceable output chip
DCG-P2 170/680* 1DMX/*4HyperDMX LPD6803, WS2801, WS2811, TM180x, TLS3001 2 Unfused (1x2 Electrical, 1x2 Logical) 512DMX/*2048HyperDMX 1 link Assembled Board: $53 2 Pixel Outputs share 1 DMX or 4 HyperDmx input channels
uDCG-P2 170/680* 1DMX/*4HyperDMX LPD6803, WS2801, WS2811, TM180x, TLS3001 2 Unfused (1x2 Electrical, 1x2 Logical) 512DMX/*2048HyperDMX 1 link Assembled Board: $42, Assembled Board w/Case: $48 2 Pixel Outputs share 1 DMX or 4 HyperDmx input channels
Ray Wu
(China Based)
DIYB
Electron Design
(Israel based)
AVD
ACL Wiki
ACL Thread
ACL
Onumen
RPM
Stellascapes
  • T3: DMX512 - SPI Bridge
SD Memory Card to SPI
Ray Wu
(China Based)
Light-O-Rama (LOR) to SPI
Light-O-Rama (LOR)
(USA Based)
PIXEL Extenders
  • ECG-PPX
  • ECG-PPD-A – Powered Pixel Driver - 7VDC – 12VDC input range
  • ECG-PPD-B – Powered Pixel Driver - 7VDC – 40VDC input range
  • ECG-PPD-C – 4 Channel Powered Pixel Driver - 7VDC – 40VDC input range on Channel 1
  • ECG-PPR-A – Multi-Mode Powered Pixel Receiver
  • ECG-PPI-A – Powered Pixel Injector - 7VDC-40VDC Input, 5VDC 1.5A output
E1.31 Bridges and DMX Dongles
DIYLEDEXPRESS
RPM
Discussion Thread
USB to DMX512 Output
FTDI drivers for dongles:
DC Controller Comparison Table
HolidayCoro #27 / Water Resistant / Boxed / Pigtails / 9 Test Sequences Yes 6V - 24V 3 2A 6A per 3 Ch DMX $9.49 $3.16
Audiolight Intl HD-714 US China Yes 12V - 24V 3 2A 6A DMX $8.95 $2.98
Audiolight Intl HD-712 US China Yes 12V - 24V 27 1A 15A DMX $44.21 $1.64
Leynew LN-DMXMODEL-3CH-LV12 US China Yes 12V 3 2A 6A DMX $7.49 $2.49
DIYLEDExpress Ren24DC Built or Kit 5,7-24vdc 24 4A 30A x 2 RS232/485, DMX $72.10 $3
DM103 Ray Wu DMX to 3 Channel
Different Styles of Pixels
Waterproofing Pixels
Null Pixels
