Pops-O-Matic ESP Programmer
Voltage Regulator
ESP Flashing Circuit
Pops-O-Matic Overview
It can take a wide variation of power input voltages (5V-25V) and can support up to 5 different power connections.
1. 5mm Terminal Block
2. 3.5mm Terminal Block
3. Micro USB
4. Mini USB
5. Barrel Terminal Jack
Order a boards
- Input Connectors - As noted earlier, you have choices for the power input connector. You can populate the board with all the connectors at the same time. The exception to this is that the 3.5mm and 5mm terminal blocks share the same space on the board.
- Power Switch - This part is optional. You can short the middle and left holes together to set the board to permanently ON. This SPDT slide switch has
Click Here:
The BOM's are:
Mouser BOM is in Post #35
Arrow BOM is in Post #48
Digikey BOM is in Post #49
Wiring The ESPixel Pops
A Key Point Regarding Power
Programming the ESP-01 Module
The heart and soul of the pixel stick variants is the firmware that runs on the the ESP-01 module. Work has been done to consolidate to one common set of code.
Upload the firmware
