Pops-O-Matic ESP Programmer
Voltage Regulator
ESP Flashing Circuit
Click Here:
Pixel Pops & Tiny
Therefore, if you use the TINY board, you must have some other mechanism in order to program the ESP-01 module.
Order your own boards
If ukewarrior is out of boards, you can order them in groups of 3 from OSHPark: Click here for the Ordering link at OSHPark to order your own boards
Fuse Holder
5A Fuse
Click Here:
The BOM's are:
Mouser BOM is in Post #35
Arrow BOM is in Post #48
Digikey BOM is in Post #49
Wiring The ESPixel Pops
A Key Point Regarding Power
Programming the ESP-01 Module
The heart and soul of the pixel stick variants is the firmware that runs on the the ESP-01 module. Work has been done to consolidate to one common set of code.
Upload the firmware
