ESPixel Stick & ESPixel Pops
![Version V2](/wiki/images/9/95/Pops_tiny.jpg)
![Version V2](/wiki/images/3/30/Pops_board.jpg)
![Version V2](/wiki/images/2/29/Pixel_Pops_Tiny_Picture_2.jpg)
Click Here:
Pixel Pops & Tiny
![small](/wiki/images/6/67/Built_unit_with_quarter_for_scale.jpg)
Order your own boards
Fuse Holder
5A Fuse
- One Mosfet. This must be: 2N7000 or ZVN3306A, which has a T0-92-3 style package
Click Here:
The BOM's are:
Mouser BOM is in Post #35
Arrow BOM is in Post #48
Digikey BOM is in Post #49
![Version V2](/wiki/images/6/67/Built_unit_with_quarter_for_scale.jpg)
The board has a place for a second voltage regulator. This is to accommodate 5V pixels even if your input power is 12V.
The part laveled: IC1 is NOT installed if you are running 5V Pixel strings AND you must place a jumper in its place as noted on the board.
Wiring The ESPixel Pops
A Key Point Regarding Power
One thing you have to decide is if you will power your pixels through the ESPixel Stick or directly to the Pixel string.
Programming the ESP-01 Module
Under Construction
