ESPixel Stick & ESPixel Pops
![Version V2](/wiki/images/3/30/Pixel_Pops_Picture_x2.jpg)
![Version V2](/wiki/images/2/29/Pixel_Pops_Tiny_Picture_2.jpg)
The ESPixel Pops and ESPixel Pops Tiny are variations of the original ESPixel Stick by Bill Porter
The genesis of the pixel stick controllers started with designs by Bill Porter.
![small](/wiki/images/6/67/Built_unit_with_quarter_for_scale.jpg)
5. The board is small enough to fit inside a 1" thinwall PCB pipe with the PCB measuring only 24.18x33.32 mm and 24.18x24.61 mm for the tiny version. This type of pipe is listed as SDR-21.
Order your own boards
Click here for the Ordering link at OSHPark to order your own boards
- One Mosfet. This must be: 2N7000, which has a T0-92-3 style package
Click Here:
The BOM's are:
Mouser BOM is in Post #35
Arrow BOM is in Post #48
Digikey BOM is in Post #49
![Version V2](/wiki/images/6/67/Built_unit_with_quarter_for_scale.jpg)
The board has a place for a second voltage regulator. This is to accommodate 5V pixels even if your input power is 12V.
Wiring The ESPixel Pops
You can either solder on a terminal block or directly solder your wires to the board, or do a mix ! The Terminal block has 3.81mm hole spacing. (The more common 5mm terminal blocks would have made the board too wide)
One thing you have to decide is if you will power your pixels through the ESPixel Stick or directly to the Pixel string. It is possible to use the ESPixel Pops as an interface for just the data and run power to the pixels separately. This is a decision of personal preference and the fact the PCB traces can only handle so much power. Trial and error is your best approach.
