Electronics Hardware
Revision as of 23:39, 18 August 2017 by Ukewarrior (talk | contribs) (Links)
Links
SSR Direct Attach
Kit74
Hill320
Olsen 595/Grinch
Firegod
  • Documentation: Firegod
This is a modular system that supports 32 to 128 channels per serial port, in increments of 32 channels, with 100 levels of dimming (using pulse width modulation - PWM). It consists of a host controller module and one to four field modules. The SSRs are not included on these boards, and must be provided separately. The interface to this system is RS-232. This system is no longer available on a coop basis. You would need to etch your own of find someone whp has one for sale. This board is intermediate in complexity to build.
Renard
Lynx
Helix
  • Documentation: Helix
Fox Cub
Pixel Controllers
Other Controllers & Light Specific Driver Boards (High Power LEDs, Signs, Servos, etc.)
The RobG 10W RGB LED Driver Board
  • Controlled through: Renards and most any other micro-controller with PWM based 5v control ports
  • Documentation: Wiki Entry for this board
This board implements a constant current driver for the commonly found 10W RGB LED modules. The board supports remote power injection and is very simple to interface to most DIYC controllers. (non-pixel types)
LedTriks
Triks-C
LEDTRIKS LED PANELS
  • Connected to LEDTRIKS Controller: via CAT5 cables.
  • Documentation: LEDTRIKS Panel
PIX-C
  • Documentation: PIX-C
JEC Pixel Displays
  • Controlled through: DMX
rgbLED
Color Stick
RS485 Splitter
Power Distribution Boards
With the introduction of iOT (Internet of Things) technology, the ability to have wireless wifi devices has now reached a point of easy use and very low cost. This section covers gear that utilizes these technologies.
E1.31 Bridges
6 Port e1.31 Bridge by DIYLEDEXPRESS
3 & 4 Port E1.31 Bridge/SPI Controller by HolidayCoro
The following controllers have dedicated, built-in RS485 interfaces in-addition to 16 SPI outputs:
3 Ports: AlphaPix 16
4 Port e1.31 Bridge by RPM
FM Transmitters & Antennas
DMX Boards, both converters and light controllers
This section is under construction, please consider all links broken below
Digital Input/Output Cards
