ESPixel Stick & ESPixel Pops
The ESPixel Pops is a variation of the original ESPixel Stick
The ESPixel Pops is the most basic of the Pixel Stick designs. It is a fully through hole PCB with no smd(surface mount) components. Therefore, it is easily built by most anyone with basic soldering skills
1. A
2. B
3. C
4. C
The Schematic can be viewed by clicking on this link:
[ESPixel_PopsSchematic.pdf ESPixel Pops Schematic]
Order your own boards
Home Etch
If you want to home etch an SSR, please go to the wiki entry for the SSRneon-G2 which is a home etch friendly design and has design files specifically built for home etching.
(ref: SSRneon-G2 wiki entry )
Fuse Rating
BOM for 120VAC Operation:
QTY Mouser #: Description
2 606-A9A Neon Lamp 65VAC .7mA NE-2E marked NE1, NE2 (See the note below for an alternative source)
OR
511-BTA06-600S Triacs 6 Amp 600 Volt marked U1, U2, U3, and U4
1 534-3527C Fuse Cover
4 859-MOC3023 Optocomponents Optocoupler marked IC1, IC2, IC3 and IC4
See above for TA-200 sources.
1 TA-200 Enclosure
1 Male Plug Power Cord, Rated for 10A Minimum
Leaving out the LED Channel Indicators
I don't want the LED Indicators !
How to use LEDs of many colors for the Channel Indicators
Red LEDs have a typical forward voltage (Vf) of 2.0 volts. However, other colors, like green, have a Vf of 3.x volts. Therefore, if you use a LED with a Vf in this range, you should replace the 220 ohm resistor connected to that LED with a 180 ohm resistor.
The basic equation is:
V(supply): Supply voltage, in our case 5V
Vf(opto): Forward voltage of the opto emitter, 1.5V max, 1.15 typ
Vf(LED): Forward voltage of the LED, for the LEDs I use it is 2.0V
Vol: Low voltage output level, For the purposes of this calculation, a value of 0.33V max, 0.18V typical was used.
If you are concerned about the current draw then you can increase the value of R based on the typical values (i.e. to either 270 or 300). However, there is a concern that with the temperature extremes these devices are used in, this would push them closer to the max values and cause erratic behavior.
Wiring The SSRneon
Controller Output Pinout
