Wireless Technologies
The revolution of iOT (Internet of Things) has been beneficial to the Christmas Lighting community by bringing the ability to incorporate industry standard wifi as a connection method for our lighting controllers. The advantage of wireless is of course the reduction in cables and potentially more flexibility in light element design.
One great feature of this technology is that it is very inexpensive. The first widely adopted technology is based on a chip know as the ESP8266. Here is a link to wiki entry for this little beauty if you care to read up on it: ESP8266 wiki entry
Designs with detailed information
- John Wilson's DC SSR 4 Channel
 - Andrew Williams DCSSR Version 2.4 4-Channel
 - Dirknerkle's Low cost ACSSR (DirkCheap)
 - Chris and John's SSRez 4 Channel
 - Sean Bowf Standard 4-Channel
 - Dave & Greg's SSRneon-G2-LED 4-Channel
 - Dave's SSRneon-G2 4-Channel
 - Robert Stark 4-Channel
 - Robert Stark 6-Channel Power Strip
 - Robert Stark 12-Channel
 - Frank Kostyun 4-Channel
 - David Fansler 8-Channel
 - Orien Love 4-Channel Enclosure
 - Rodney Harris Pod Enclosure
Components
There are a few basic components that make up a Solid State Relay.
Triac
Optocoupler
Fuse
Resistors
Wiki Links
4 Channel SSR Parts List Sean Bowf Coop Board
4 Channel SSROZ Assembly Instructions
