Different Styles of Pixels
Pixel Properties
Form Factor
- Strings / Nodes - Can be any purchased in any custom length, but depending on a variety of factors, more then 50 pixels may require Power Injection. It important to remember that Pixel strings should never be strung using their wire to support them like you would with regular light stings. This will damage the Pixels and their waterproofing. Since they are generally custom made, you can request your vendor to make the spacing between units to custom lengths. Common methods to support Pixel strings include using cable ties or electric tape to attach them to PVC pipe, EMT electric conduit or Plastic Strapping or PixNode strips [1]. Strings / Nodes are commonly used to make Megatrees, Minitrees and Leaping Arches.
- 12mm pixel - This is the most common Pixel type. They are often referred to as Bullet Shaped. It actually contains a 8mm LED inside the housing. The 12mm refers to the outer diameter of the package. These were originally designed to mount inside of enclosures and are used for large advertising display screens.
- 12mm pixel (square / flat) - These pixels can come with the wire coming either out of the back of the Pixel or the side of the Pixel. There has been some issues with the silicone injection molded units that have the wires coming out of the side not sealing and allowing water into the pixels.
- Pixels with Lens - There are a variety of Pixels available with Plastic Lens mounted on the RGB LED to make them look closer to a traditional C7 or C9 incandescent light. Common models include the Ge Color Effects (GECE), the Pixabulb by diyledexpress.com, the Cosmic Color Bulbs by Lightorama.com and the Technicolor Pixel by Ray Wu. Vendors like Ray Wu also sell Plastic lens that can be glued onto regular 12mm Pixel strings to achieve a similar look.
- Epoxy Resin Coating
- Solid Silicone
- Solid Epoxy Resin
RGB LEDs per meter
LED Type
Waterproofing
- Injection Molded Silicone - These units have the wires coming out of the back or side and the biggest issue has been the failure of the silicone used to seal to the wires. Many early pixels had obvious areas where water could easily get into the Pixels. While many of the newer unts have better sealing, there is always the potential for the water to wick in along the wires if there is any stress on the wires due to wind pulling on the wires.
Wire Size
- LPD1101
- UCS6909
- UCS6912
- LPD8809 ?
- SM16715
- P9813 - 4 wire
- P9816 - 4 wire
- TLS3002
- CYT3001 Datasheet (Chinese)
- CYT3005 - 3 wire
- MY9942 (Native DMX)
- MY9943 (Native DMX)
DIYLEDEXPRESS
HolidayCoro.com
| C9/Bulb | WS2811 | 50 Pixels (32'-8") | 12 vdc | 5 (8" Spacing) | 5 (8" Spacing) | Product Page | IP68/Cast Epoxy/ 7/8" Base / 1" x 1" Faceted Bulb | |
| C9/Bulb | WS2811 | 50 Pixels (40'-10") | 12 vdc | 4 (10" Spacing) | 4 (10" Spacing) | Product Page | IP68/Cast Epoxy/ 7/8" Base / 1" x 1" Faceted Bulb | |
| C9/Bulb | WS2811 | 50 Pixels (49') | 12 vdc | 3.3 (12" Spacing) | 3.3 (12" Spacing) | Product Page | IP68/Cast Epoxy/ 7/8" Base / 1" x 1" Faceted Bulb | |
| String/Node/8mm/Bullet | WS2811 | 50 Pixels (12'-6") | 12 vdc | 13 (3" Spacing) |
13 (3" Spacing) |
Product Page | IP68/Cast Epoxy+Silicone Sleeve, 8mm LED/12mm Base | |
| String/Node/8mm/Bullet | WS2811 | 50 Pixels (24') | 12 vdc | 6.5 (6" Spacing) |
6.5 (6" Spacing) |
| String/Node/8mm/Bullet | WS2811 | 50 Pixels (12'-6") | 5 vdc | 13 (3" Spacing) |
13 (3" Spacing) |
| String/Node/8mm/Flat Base | WS2811 | 50 Pixels (12'-6") | 12 vdc | 13 (3" Spacing) |
13 (3" Spacing) |
| String/Node/8mm/Flat Base | WS2811 | 50 Pixels (12'-6") | 5 vdc | 13 (3" Spacing) |
13 (3" Spacing) |
| Module / Rectangle | WS2811 | 1 Pixel | 12 vdc | 30 | 10 | Product Page | 3 of 5050 RGB LEDs, 6" Wire Spacing,IP68/Epoxy Sealed | |
| Module / Square | WS2811 | 1 Pixel | 12 vdc | 36 | 12 | Product Page | 3 of 5050 RGB LEDs, IP68/Epoxy Sealed, Stamped Steel Base | |
| Strip | WS2811 | 50 pixels (5m/16.5 ft) | 12 vdc | 30 | 10 | JST Plug Waterproof Plugs |
Silicone Tube, Black or White PCB Colors, High Brightness LEDs | |
| Strip | WS2811 | 80 pixels (5m/16.5 ft) | 12 vdc | 48 | 16 | Product Page | Silicone Tube, Black or White PCB Colors, High Brightness LEDs | |
| Strip | INK1003/WS2811 | 240 pixels (4m/13.1 ft) | 12 vdc | 60 | 60 | Product Page | Silicone Tube, Black or White PCB Colors, High Brightness LEDs |
Light-O-Rama (LOR)
(USA Based)
Ray Wu
Retail Store (i.e. Lowes)
Seasonal Entertainment
Stellascapes
DIYLEDEXPRESS
HolidayCoro
| Nodes / Sring | 50 nodes 12' 6" string length 3" Spacing |
12vdc | link | IP68 | |
| Strip | 5m | 12vdc | link | silicone tube | |
| Module (rectangular) | 20 nodes | 12vdc | link | 3 LEDs / IP68 | |
| Module (square) | 20 nodes | 12vdc | link | 3 LEDs / IP68 |
Ray Wu
(China Based)
| Form Factor | IC | Length | Voltage | LEDs per Meter | ICs per meter | Link | Image | Price | Price per LED | Note |
| String | None | 50 nodes (5m) | 12vdc | 10 | 0 | link | $19.99 | $.40 | IP68 | |
| String (square) | None | 50 nodes (10m) | 12vdc | 5 | 0 | link | $42.99 | $0.86 | IP68, RGB C7 lens | |
| String (square) | None | 50 nodes (10m) | 12vdc | 5 | 0 | link | $44.99 | $0.90 | IP68, RGB C9 lens | |
| Strip | None | 5m | 12vdc | 30 | 0 | link | $35.99 | $7.20/m | IP68, Silicone filled |
Ray Wu
(China Based)
Waterproofing Pixels
Null Pixels
