- Pixel Controllers
- Dumb RGB Controllers.
- E1.31 (DMX over Ethernet)
- Advanced Features
- Etc.
PIXEL CONTROLLERS
HolidayCoro
| Model | Max Pixels | DMX Universes | Pixels Supported | Output Connectors | String Outputs | Image | Link | Price | Manual/Videos | Note |
| AlphaPix 4 | 2,720 | 16 UniCast 16 MultiCast |
WS2811,WS2812,WS801,WS2803 TM1804,TM1803,TM1812,SM16715 TLS3001,TLS3002,CY3005 LPD6803,D705,LPD1101 |
Product Link | Assembled $99.99 | Coming Soon | Includes one dedicated RS-485/DMX output (does not use a pixel output), 28A per Controller/7.5A per Output, LCD Interface, WEB Interface | |
| AlphaPix 16 | 5,440 | 32 UniCast 32 MultiCast |
Product Link | Assembled $174.99 | Coming Soon | Includes three dedicated RS-485/DMX outputs (does not use a pixel output), 24A per Bank, 2 Banks per Controller (48A Total)/3A per Output, LCD Interface, WEB Interface |
Advatek Lighting Pty Ltd
| PixLite 4 | 2,720 | 16 UniCast 16 MultiCast |
WS2811,WS2812,WS801,WS2803 TM1804,TM1803,TM1812,SM16715 TLS3001,TLS3002,CY3005 LPD6803,D705,LPD1101 USC6909,UCS6912,SM16716,MBI6020 |
Product Link | Assembled $129.99 | General Setup Video LOR S3 Setup Video Manual |
Includes one dedicated RS-485/DMX output, 28A per Controller/7A per Output, Gamma Correction, Temp & Power Monitor | |
| PixLite 16 | 5,440 | 32 UniCast 32 MultiCast |
Product Link | Assembled $219.99 | General Setup Video LOR S3 Setup Video Manual |
Includes four dedicated RS-485/DMX outputs (does not use a pixel output), 30A per Bank, 2 Banks per Controller (60A Total)/4A per Output, Gamma Correction, Temp & Power Monitor |
SanDevices
| E6804-4 | 2040 | 7Multicast / 12Unicast | GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others | 4 Fused (1x4 Electrical, 4x1 Logical) | 6120 | Up to 12 | link | Assembled/Tested: $99, Full Kit: Price $69 Presale | Owner's Assembly | Size is 2.5" x 4", mounting holes on 2"x3" centers, compatible with CG series enclosures. Announcement | |
Joshua 1 Systems (J1SYS)
Stellascapes
| E16-II Pro | 672 | 6Unicast | Stella-black | 16 Fused (? Electrical, ? Logical) | 2016 | ? | link | Assembled Board: $?? | With power supply and Neutrik XLR, power and ethernet chasis connectors | ||
| E2 | 170 | 1Unicast | Stella-black | 2 ? | 512 | ? | link | Assembled Board: $?? | With power supply,operates on low voltage DC (12-48V) |
DMX512 to SPI
HolidayCoro
| Model | Max Pixels | DMX Channels | Pixels Supported | Output Connectors | Image | Link | Price | Note |
| EasyPix V2 | 170 | 512 | WS2811,WS2812,WS801,WS2803 TM1804,TM1803,TM1812,SM16715 TLS3001,TLS3002,CY3005 LPD6803 |
Product Link | $39.99 | Null pixels, Reverse order,Push button setting with back-lit LCD screen, built-in sequences, replaceable output chip |
| DCG-P2 | 170/680* | 1DMX/*4HyperDMX | LPD6803, WS2801, WS2811, TM180x, TLS3001 | 2 Unfused (1x2 Electrical, 1x2 Logical) | 512DMX/*2048HyperDMX | 1 | link | Assembled Board: $53 | 2 Pixel Outputs share 1 DMX or 4 HyperDmx input channels | ||
| uDCG-P2 | 170/680* | 1DMX/*4HyperDMX | LPD6803, WS2801, WS2811, TM180x, TLS3001 | 2 Unfused (1x2 Electrical, 1x2 Logical) | 512DMX/*2048HyperDMX | 1 | link | Assembled Board: $42, Assembled Board w/Case: $48 | 2 Pixel Outputs share 1 DMX or 4 HyperDmx input channels |
Ray Wu
(China Based)
DIYB
Electron Design
(Israel based)
AVD
ACL
Onumen
RPM
Stellascapes
- T3: DMX512 - SPI Bridge
SD Memory Card to SPI
Ray Wu
(China Based)
Light-O-Rama (LOR) to SPI
Light-O-Rama (LOR)
(USA Based)
PIXEL Extenders
- ECG-PPX
E1.31 Bridges and DMX Dongles
DIYLEDEXPRESS
RPM
USB to DMX512 Output
- Enttec Open DMX USB
- Enttec DMX USB Pro
- RPM DIY USB to DMX Adaptor
- RJ's LYNX DMX DONGLE
FTDI drivers for dongles:
- FTDI VCP Drivers
| Audiolight Intl | HD-714 US China | Yes | 12V - 24V | 3 | 2A | 6A | DMX | $8.95 | $2.98 |
| Audiolight Intl | HD-712 US China | Yes | 12V - 24V | 27 | 1A | 15A | DMX | $44.21 | $1.64 |
| Leynew | LN-DMXMODEL-3CH-LV12 US China | Yes | 12V | 3 | 2A | 6A | DMX | $7.49 | $2.49 |
| DIYLEDExpress | Ren24DC | Built or Kit | 5,7-24vdc | 24 | 4A | 30A x 2 | RS232/485, DMX | $72.10 | $3 |
Different Styles of Pixels
Waterproofing Pixels
Null Pixels
