10W-RGB-LED-DRIVER
Revision as of 18:46, 10 January 2015 by Ukewarrior (talk | contribs) (Schematic)
Version G2
Version G2
As a separate 12V power source is applied to the board, three additional connections are made to the board that can control the brightness of each color separately. These connections are typically the 5V DC output pins from a microcontroller.
10W RGB LED
small
small
Color: RGB
Beam Angel: 140 degrees
Life span: >50,000 hours
Version G2
Version G2
BOM for 12V DC power input:
QTY    Board ID           Description
3      IC1,IC2,IC3        PT4115 by Powtech: 30V, 1.2A Step-down High Brightness LED Driver with 5000:1 Dimming
3      L1,L2,L3           100uH Inductor, 6x8mm, 700ma
3      T1,T2,T3           Transistor  FJN3314R
3      D1,D2,D3           Diode    1N5819
Assembly Tips
Mounting the LED:
Wiring examples
REN48LSD connections
click on the picture for a larger version of the REN48LSD hookup diagram
Installation examples
pictures of installations .
