10W-RGB-LED-DRIVER
Revision as of 17:33, 10 January 2015 by Ukewarrior (talk | contribs) (Schematic)
Version G2
Version G2
This circuit board is specifically designed to drive 10W RGB LED modules. It has the ability to drive a 10W RGB LED via a 5v DC PWM signal that will therefore allow dimming of each individual color. As a separate 12V power source is applied to the board, three additional connections are made to the board that can control the brightness of each color separately. These connections are typically the 5V DC output pins from a microcontroller.
10W RGB LED
small
small
This board was specifically designed for a commonly found 10W RGB LED. These square form factor LEDs can be found at many online stores, ebay and aliexpress.
Color: RGB
Beam Angel: 140 degrees
Life span: >50,000 hours
BOM for 12V DC power input:
QTY    Board ID           Description
3      IC1,IC2,IC3        PT4115 by Powtech: 30V, 1.2A Step-down High Brightness LED Driver with 5000:1 Dimming
3      L1,L2,L3           100uH Inductor, 6x8mm, 700ma
3      T1,T2,T3           Transistor  FJN3314R
3      D1,D2,D3           Diode    1N5819
Assembly Tips
This board had only one part that will take some small amount of skill to install, the PT4115.
