10W-RGB-LED-DRIVER
Revision as of 00:58, 10 January 2015 by Ukewarrior (talk | contribs) (BOM)
Version G2
Version G2
This circuit board is specifically designed to drive 10W RGB LED modules. It has the ability to drive a 10W RGB LED via a 5v DC PWM signal that will therefore allow dimming of each individual color. As a separate 12V power source is applied to the board, three different connections are made to the board that can control the brightness of each color separately. These connections are typically the 5V DC output pins from a microcontroller.
10W RGB LED
small
small
This board was specifically designed for a commonly found 10W RGB LED. These square form factor LEDs can be found at many online stores, ebay and aliexpress.
Color: RGB
Beam Angel: 140 degrees
Life span: >50,000 hours
BOM for 120VAC Operation:
2      606-A9A            Neon Lamp 65VAC .7mA NE-2E marked NE1, NE2  (See the note below for an alternative source)
1      571-5556416-1      Modular Jacks 8 PCB TOP ENTRY marked J1
4      511-BTA04-700T     Triacs 4 Amp 700 Volt marked U1, U2, U3, and U4
            OR
       511-BTA06-600S     Triacs 6 Amp 600 Volt marked U1, U2, U3, and U4
1      534-3527C          Fuse Cover
5      604-WP7104IT       LED Standard HI EFF RED TRANS marked LED1, LED2, LED3, LED4, LED5
1      660-CF1/4C681J     1/4Watt Axial Carbon Film Resistors 680ohms 5% marked R9
4      660-CF1/4C221J     1/4Watt Axial Carbon Film Resistors 220ohms 5% marked R1, R2, R3, R4
2      660-CF1/4C104J     1/4Watt Axial Carbon Film Resistors 100Kohms 5% marked R10, R11
4      859-MOC3023        Optocomponents Optocoupler marked IC1, IC2, IC3 and IC4
4      571-1-390261-1     IC Sockets 6P ECONOMY TIN marked IC1, IC2, IC3, IC4
5      571-2828372        Terminal Blocks 5.08MM PCB MOUNT 2P marked TB1, TB2, TB3, TB4, TB5
== Order your own boards  ==
You can order your own boards with the information given below, or you can contact: ''gmbartlett'' on the DIYC forum to see if he has any in stock.
The PCB industry has a standard for the definition of a PCB.  It's called a 'gerber' file.
This is a set of files that have the actual instructions that tell the machines how to operate.
The Gerbers for the SSRneon-G2-LED are found at this link:
[http://doityourselfchristmas.com/forums/dynamics/attachment.php?attachmentid=416&d=1333648310 Zip File containing the SSRneon-G2-LED Gerber files]
== Home Etch  ==
<br>
<br>
If you want to home etch an SSR, please go to the wiki entry for the SSRneon-G2 which is a home etch friendly design and has design files specifically built for home etching. <br>
(ref: [http://www.doityourselfchristmas.com/wiki/index.php?title=SSRneon SSRneon-G2 wiki entry] )
</p>
== Fuse Rating ==
[[Image:fuse.jpg|right|fuse]]
<p>
Various fuse values have been listed for all the various 4 port SSRs.  e.g. SSRneon, Sean Bowf, SSRoz, SSRez.
</p><p>
The fuse value is determined by several factors.  Key among these is the amount of current, in total, that is flowing through the SSR. Another factor is the copper weight and size of the main AC traces.  (Copper weight is how 'thick' the copper is on the board.)  </p><p>
The SSRneon-G2 has the largest amount of AC trace copper weight of any of the DIY SSRs to date. (4/22/2012)  With that said, a Fuse of 4 amps is a good place to start.  If you want to drive more then 1 amp through any individual TRIAC (channel), then you can ramp up to as high as an 8 amp fuse.  However, once you move above 1 amp through any single TRIAC (channel), you should put a heat sink on the TRIAC(s).  This does not mean you can run 8 amps through a single TRIAC (channel).  A single TRIAC can handle 2.0 amps max.  You will notice that the copper traces that connect to any one TRIAC are no where near the size of the main AC copper trace.  So, just because the TRIAC you use may be rated for 3 or 4 or more amps doesn't mean the SSRneon-G2-LED can safely drive it at that amperage.
</p><p>
It is this authors opinon that you should run as low a fuse value as possible for your needs.  For example, this author runs a 100% LED based show and runs several SSRneons with 2 amp fuses.
== Disclaimers ==
'''USE the SSRneon-G2-LED at Your Own Risk !'''</p>
'''The SSRneon-G2-LED has NO warranty expressed or implied'''
<p>
== BOM - Bill of Materials ==
'''BOM for 120VAC Operation:'''
<pre style="font-size: 10pt">
            OR
1      504-GMC-8          5mm x 20mm Medium Time Delay Fuses 125VAC 8A Med Time Delay
See above for TA-200 sources.
1                         Male Plug Power Cord, Rated for 10A Minimum
Leaving out the LED Channel Indicators
I don't want the LED Indicators !
How to use LEDs of many colors for the Channel Indicators
The board was designed and silkscreened to use a 220 ohm resistor and red LED for the the channel indicator. However, other colors can be used.
Red LEDs have a typical forward voltage (Vf) of 2.0 volts. However, other colors, like green, have a Vf of 3.x volts. Therefore, if you use a LED with a Vf in this range, you should replace the 220 ohm resistor connected to that LED with a 180 ohm resistor.
The basic equation is:
V(supply): Supply voltage, in our case 5V
Vf(opto): Forward voltage of the opto emitter, 1.5V max, 1.15 typ
Vf(LED): Forward voltage of the LED, for the LEDs I use it is 2.0V
Vol: Low voltage output level, For the purposes of this calculation, a value of 0.33V max, 0.18V typical was used.
If you are concerned about the current draw then you can increase the value of R based on the typical values (i.e. to either 270 or 300). However, there is a concern that with the temperature extremes these devices are used in, this would push them closer to the max values and cause erratic behavior.
Wiring The SSRneon
Controller Output Pinout
Pin Number Connection
1 +5v DC Power
2 Channel 1 Signal
3 reserved
4 Channel 2 Signal
5 reserved
6 Channel 3 Signal
7 Ground
8 Channel 4 Signal
Version G2
Version G2
