Vastelec FM02
Revision as of 18:53, 8 December 2014 by Jklingert (talk | contribs) (Antenna)
FM-02
click on the picture for a larger version
Vendor's Website
Data Sheet
You can also receive warranty service from the units purchased directly from www.radiant-holidays (former WLC ventures).
Pictures of FM02's in enclosures
Each FM02 installation is unique !
A gallery of over 25 different installations with pictures and 'how to build notes' is available.
Do you have a HUM ?
Some Beads split in half, some don't !
A Split Ferrite bead
A multi wrap Ferrite bead
There are some good pictures in the wiki-pedia-: http://en.wikipedia.org/wiki/Ferrite_bead
Audio
3.5mm stereo plug
Schematic and PCB layout
schematic
schematic
Detailed Board Dimensions
board dims
board dims
board dims 2
board dims 2
Antenna
Most DIY'ers will want to convert this to the BNC type of connector because BNC components are easier to find. The converter shown below will correctly hook to the FM02. SMA is the smaller gold colored part of the connector. You can purchase the adapters from diyledexpress.com or from ebay.
smatobnc
smatobnc
You will need to buy or make an antenna. There are MANY different designs for antennas. A large number of DIYers have made a type of antenna known as a dipole. This is an easy to make antenna that will serve almost anyone's needs. Here is a link to a pdf with instructions to make your own: How to Make a Dipole Antenna
More recently, DIYC member Jhinkle published a paper for an antenna design that is easier to build with very good transmission characteristics.
Here is the link to a posting on the subject. DIYC discussion thread
You can go directly to the excellent design and build paper at this link: pdf paper for a ground plane antenna
What Frequency to Use
NOTE: There are seasonal radio stations. A open frequency in June may be used in December. You should plan accordingly.
http://www.radio-locator.com/
Where can I get one of these wonderful FM transmitters ?
RDS hookup information
This section involves modifying your FM02.
If you do this, you void the warranty.
Here is a picture of hooking the pira mini-RDS unit up to an FM02
fm02rds
fm02rds
fm02rds
fm02rds
hookupdetail
hookupdetail
Pira Mini-RDS hookup diagram:
minirdshookupdetail
minirdshookupdetail
Additional Modifications
Why you should care about the transmitting power of your transmitter (FCC regulations)
Did you know if you use an FM transmitter the FCC can inspect your transmitter at any time without a search warrant?!! It's true. If the FCC finds you operating equipment that is in violation, you must give them your transmitter so they can destroy it ! If you don't, you will face a large fine. Read through this FCC website discussing the use of an FM transmitter as an 'unlicensed' operator. Click here: FCC information for unlicensed operators
PART15:
Please note: This should be considered an advanced modification. There are hundreds of FM02 in use by the DIYC community and the vast majority use them without this modification.
fm02block
fm02block
