Soldering Basics
Revision as of 00:08, 30 November 2014 by Jklingert (talk | contribs) (Chipquick)
Soldering quick tips
Soldering Quick Tips
The best solder joints come from a combination of good solder, good tools and practice.
A good solder like Kester 44 (use 63/37 with flux core and 0.032" diameter 1/2lb spool for starters) along with a good temperature controlled soldering like the CSI 1A, CSI 3DLF or the Tenma 21-10115 will result in good solder joints.
It is common to set the iron temperature to 650 - 750 °F for a good solder joint.
For under $10 you can buy a lot of spare parts and pcbs to practice on listed below
You do not have to clean most flux residue from a soldered joint, but it can help to clean them to see if there are bad joints.
Do not attempt to solder circuits that are connected to live power.
Be very careful, soldering irons are very hot, they can burn you or start a fire it you are careless.
Solder Types
Electronic Solder
  • Lead/Tin solder
  • "Silver" solder
  • Lead-free solder
Lead/Tin
Lead/Tin solder is available in different mixtures of the two metals. There are two popular mixtures available:
*63/37 (Called a eutectic mixture) It contains 63% Tin and 37% Lead and melts exactly at 183 °C (361 °F)
*60/40 Is a common solder that contains 60% Tin and 40% Lead and melts over a range of 183–190 °C (361–374 °F)
They both work fine for electronic work. It is a personal choice as to which you use. The main difference is how they both cool. The 60/40 when cooling goes through a "slushy" phase and does not always result in a bright shiny joint. The 63/37 eutectic solder cools quickly and does not go through the slushy phase. Many people prefer the 63/37 solder, but will use whatever is available when they have it!
Care should be used when handling Lead based solders, you should always wash your hands when you are finished soldering and before eating. In practice there are very low levels of lead and decomposition products from the flux in the smoke from soldering, so it is a good idea to not inhale the smoke. You should also not put the solder in your mouth or chew on it....
"Silver" Solder
Silver solder is similar to Lead/Tin solder, but has a small amount of silver (2-4%) added to it. It is more expensive and is not commonly used for printed circuit board work. It is a specialty solder sometimes used for parts that are already silver plated. The common silver solder eutectic mixture that is 62% Tin/36% Lead/2% Silver melts at 179 °C (354 °F). There is also a "Hard Silver Solder" that has 80%Silver in it and it is used for soldering jewelry and not electronics.
Lead Free Solder
BEGINNERS AND CASUAL USERS SHOULD AVOID LEAD FREE SOLDER. Lead free solder became popular in Europe on July 1, 2006 due to environmental laws associated with eliminating lead. It is generally not recommended for printed circuit board soldering by hobbyists. It is harder to get a good solder joint and is only used by manufacturers using special tools and processes. It requires greater heat and is noticeably harder to get a good hand soldered joint compared to lead/tin solder. Lead Free solder is often sold right next to regular lead/tin solder in stores, so be careful when you buy your solder. If it is the only solder available, it can be used with caution. For tips on using lead free solder read this article. For tips on repair and rework with lead free solde look here. It generally comes in two compounds Tin/Copper called SnCu or Tin/Silver/Copper (96.5% Tin, 3.0% Silver, 0.5% Copper) called SAC.
Solder Forms
Solder Wire
Solder wire typically comes on spools. A 1 lb. spool will last a long time for hard core builder and 1/2lb spools are generally a good choice for most users. A 1/2lb spool should be enough for over 20K solder joints.
  • 0.020” popular for fine work and hand soldering Surface mount devices
  • 0.030” used for general soldering of through hole devices
  • 0.040" used for soldering large connectors or very large components like fuse holders
Solder Paste
Bad Solder (DO NOT USE)
Stained Glass Solder
Flux
Flux is a chemical available in either a liquid or gel form used to help make better solder joint. Flux works by reacting with any dirt or oxide corrosion on the electronic part or copper trace on the printed circuit board. It both cleans and allows the molten solder to better "wet" and flow and bond to the surfaces. Flux is commonly found in the center of solder wire and is activated by the heat of the soldering iron and becomes active and begins it's chemical process. As the liquid flux flows along the surface it activates the surfaces and allows a better bond to occur with the solder. Flux can also be used separately and can be applies as a liquid from a dispensing pen or with a brush.
While flux can deal with minor corrosion , it can not clean highly corroded parts. It is recommend that you use a fine emory cloth to buff surfaces of components or printed circuit boards that are fairly old. If the surfaces are corroded , the solder will likely not stick to the metal. It is common to brush on flux onto wires before tinning the ends of wire to ensure a better bond. It also helps to add some flux to desolder braid to help it wick the solder away from the component you are desoldering.
There are three basic types of flux used with electronic soldering.
  • Organic Acid Water Soluble Flux - This flux should be avoided since it's residues are hygroscopic. The residue attracts water and forms an acid that can attack the components if it is not very carefully cleaned off the printed circuit board. They are not recommended for hobbyist use.
  • "No Clean" Flux - "No Clean" just refers to the fact that the residues are in theory non reactive and can be left on the printed circuit board without worrying about corrosion. However some residue can trap water on it's surface and cause issues for lighting controllers that are outside and subject to condensation due to moisture and heating and cooling of the enclosure they are in.
  • Rosin Flux - This flux is made from sap from Pine trees and has different levels of additives mixed in to increase it reactivity with the oxides on the metals. The common RMA flux like found in popular solders like Kester 44 type solder leaves a residue that is non reactive and does not need to be cleaned unless the circuit will be exposed to high temperatures (>65 C).
While not mandatory, it is strongly recommended that when you are finished soldering and before you install integrated circuits in their sockets, that you clean all soldered joints. This allows you to better identify poorly soldered joints and eliminated potential issues with conductivity and shorts due to condensation.
Flux Remover
When you are finished soldering a board it is common and advised that you cleang Flux residue off the printed circuit board. It is often seen as either a clear deposit, or sometimes a more burned brown stain around and on the solder joint. This is done using various solvents to help dissolve and wash away the flux residue. It is best done outdoors with good ventilation. The solvents are toxic and flammable and should be done away from flame or spark. Many people use a glass pyrex baking dish to soak the boards in and scrub with either a toothbrush or hog hair brush to clean the stubborn deposits. The flux remover comes in either liquid form or in a spray can.
There are various mixtures of solvents that are available to remove flux residue. One common one is sold by McMaster Carr and is a 12oz spray can. There are also various options from Chemtronics and MG Chemicals. Some care must be used when choosing solvents for cleaning, some aggressive solvents can attack plastic parts on your printed circuit boards.
Many people use high quality Isopropyl Alcohol available from your local drugstore. Use the 90+% concentration to avoid a milky haze that can come from the lower concentration alcohol. Here is a technical article discussing using isopropyl alcohol to clean electronics.
Always wear proper personal protective gear including gloves and goggles when cleaning flux residue off of printed circuit boards.
There are several threads in the forums about cleaning flux residue like here, here or here.
Soldering Irons
How to select an iron
Temperature Controlled
Analog
CSI 1A
Hakko FX888D
Weller WES51
Digital
CSI 3DLF
Tenma 21-10115
Low Cost Uncontrolled
Soldering Guns
Soldering Guns
How to Solder
Soldering Hints
  1. When soldering ic sockets, solder two opposite corners in first. Then with a gentle pressure press the socket against the board and reflow the two pins to get it to seat flat against the pcb.
  2. When soldering 3 pin devices like MOSFETS and TRIACS, solder the center pin in first, then with a slight pressure, straighten the device and reflow the one pin to help straighten the device out.
  3. When soldering TRIACS to the SS Series of controllers like the SS24, first attach all of the TRIACS to the heatsink loosely and solder the two end TRIACS in place first getting the entire row of devices straight and properly aligned.
Preparation
Clean the PCB and part from heavy dirt / oxidation
Secure the board and attach the part
Preheat the soldering iron
Clean the soldering iron tip
Clean Tip Hints
Tin the soldering iron tip
Iron Temperature
Soldering technique
"5 Second Rule"
Apply heat to pcb and part
Add solder to joint
Remove Iron and Inspect
Trim excess lead
How To Solder Videos
How To Solder Guides
Common Soldering Problems
Good Guide to soldering problems
How to Desolder
Desoldering
tips
Desoldering Hints
Desoldering demonstration video
Desolder Braid
Desoldering Wick
http://www.chemtronics.com/descriptions/document/SIZINGGUIDE_LR.pdf
video
Solder Sucker
Desoldering Pump "SOLDAPULLT"
Radio Shack Desoldering Bulb
Radio Shack Spring loaded
Desoldering Iron
Radio Shack Desoldering Iron
Hakko 808 Desoldering gun
Circuit Specialists 474A Desoldering station
Chipquick
Chipquick is a special alloy that you add to existing solder on a board that lowers the melting point of the solder and allows an easier removal of high pin count surface mount devices.
Demo video
Soldering Tools
Soldering Iron Tips
Wire Cutters
Holders
3rd Hand
Board Holders
Tweezers
Painters Tape
Magnifying Glass
Tip Cleaner
Soldering Iron Stand/ Holder
Electrostatic Discharge (ESD) Mat
Hand Tools
Fume Extractor
Build your own fume extractor
Vendors
Hobby KingSoldering irons
Kester Solder Solder
How to Practice Soldering
After you buy your Soldering iron and some solder, it is helpful to practice on some noncritical parts before you build your lighting controllers.By practicing on spare parts and boards you can improve your skills and learn how to solder different parts to a pcb.
Through Hole Soldering Parts
Description SKU Quantity
Small StripBoard 94x53mm (Copper) A-5031 2
Big StripBoard 110x93mm (Copper) A-2384 1
Prototyping Board 142x74mm A-5052 1
8 pin DIP IC Socket Adaptor Solder Type A-001 4
14 pin DIP IC Socket Adaptor Solder Type A-004 4
6 pin DIP IC Socket Adaptor Solder Type A-624 4
680 OHM 1/4W 5% Carbon Film Resistor A-2075 20
1K OHM 1/4W 5% Carbon Film Resistor A-624 20
0.1uF 50V Multilayer Monolithic Ceramic Capacitor A-214 5
LED 5mm Red Super Bright A-1554 5
BTA06-600C BTA06-600 Triac 600V 6A BTA06-600C 1
1N4004 Diode 1A 400V A-156 4
DG301 Screw Terminal Block 2 Positions 5mm A-668 3
IRLU024 MOSFET 65 mOhm 17A 55V N-channel I-PAK-3 IRLU024NPBF A-1453 1
LM7805 L7805 7805 Voltage Regulator IC 5V 1.5A A-179 1
40 Pin 2.54mm Single Row Pin Header Strip A-197 1
47uF 16V 105C Radial Electrolytic Capacitor 5x11mm A-4522 5
Surface Mount Devices (SMD) Practice Kit
Practice Kit
Another Practice Kit
DIYC Forum Threads
Soldering Irons
Desoldering irons
Desoldering tips
Desolder braid
Solder and soldering Related Articles
Types of solder
Choosing a soldering iron
Soldering Safety Warnings by Weller
