Soldering Basics
Soldering quick tips
 A good solder like Kester 44 (use 63/37 with flux core and 0.032" diameter 1/2lb spool for starters) along with a good temperature controlled soldering like the CSI 1A, CSI 3DLF or the Tenma 21-10115 will result in good solder joints. It is common to set the iron temperature to 650 - 750 °F for a good joint. For under $10 you can buy a lot of spare parts and pcbs to practice on listed below You do not have to clean most flux residue from a soldered joint, but it can help to clean them to see if there are bad joints. Do not attempt to solder circuits that are connected to live power. Be very careful, soldering irons are very hot, they can burn you or start a fire it you are careless.  |
Solder Types
Electronic Solder
- Lead/Tin solder
 - "Silver" solder
 - Lead-free solder
Lead/Tin
"Silver" Solder
Lead Free Solder
- Lead free solder became popular in Europe on July 1, 2006 due to environmental laws associated with eliminating lead. It is generally not recommended for printed circuit board soldering by hobbyists. It is harder to get a good solder joint and is only used by manufacturers using special tools and processes.
Solder Forms
Solder Wire
Solder Paste
Bad Solder (DO NOT USE)
Lead Free Solder
Lead Free solder has its roots in Europe due to certain restrictive environmental regulations. It requires greater heat and is noticeably harder to get a good hand soldered joint compared to lead/tin solder. Lead Free solder is often sold right next to regular lead/tin solder in stores, so be careful when you buy your solder. BEGINNERS AND CASUAL USERS SHOULD AVOID LEAD FREE SOLDER. If it is the only solder available, it can be used with caution. For tips on using lead free solder read this article. For tips on repair and rework with lead free solde look here. It generally comes in two compounds Tin/Copper called SnCu or Tin/Silver/Copper (96.5% Tin, 3.0% Silver, 0.5% Copper) called SAC.
Stained Glass Solder
Flux
Flux Remover
http://www.chemtronics.com/c-263-flux-removers.aspx
http://www.mgchemicals.com/products/solder/flux-removers/
Soldering Irons
Temperature Controlled
Analog
Digital
Low Cost Uncontrolled
Soldering Guns
How to Solder
How To Solder Videos
How To Solder Guides
Preparation
Clean the PCB and part from heavy dirt / oxidation
Secure the board and attach the part
Preheat the soldering iron
Clean the soldering iron tip
Tin the soldering iron tip
Iron Temperature
Soldering technique
Common Soldering Problems
Good Guide to soldering problems
How to Desolder
Desoldering demonstration video
Desolder Braid
http://www.chemtronics.com/descriptions/document/SIZINGGUIDE_LR.pdf
Solder Sucker
Desoldering Iron
Circuit Specialists 474A Desoldering station
Chipquick
Soldering Tools
Soldering Iron Tips
Wire Cutters
Holders
3rd Hand
Board Holders
Tweezers
Painters Tape
Magnifying Glass
Tip Cleaner
Soldering Iron Stand/ Holder
Electrostatic Discharge (ESD) Mat
Hand Tools
Fume Extractor
Vendors
Hobby KingSoldering irons
Kester Solder Solder
How to Practice Soldering
After you buy your Soldering iron and some solder, it is helpful to practice on some noncritical parts before you build your lighting controllers.By practicing on spare parts and boards you can improve your skills and learn how to solder different parts to a pcb.
Through Hole Soldering Parts
| 1K OHM 1/4W 5% Carbon Film Resistor | A-624 | 20 |
