FM02 Gallery
Pictures of Various FM02 and other VAST product Installations . . . . . . Click on the pictures !
			By OregonLights.
FM02
			By OregonLights.
FM02
			By Underdog.
FM02
			By Underdog.
FM02
			By CaptKirk.
FM02
Mounted in an Aluminum case -
			By chelmuth.
FM02
			By chelmuth.
FM02
			By smartalec.
FM02
			By RobDude30.
FM02
			By RobDude30.
FM02
			By rkhanso.
FM02
			By rkhanso.
FM02
			By klanger.
			By AURBO99.
			By AURBO99.
			By imbluenote.
			By kingofkya.
			By dmcole.
1 Watt VAST unit
			By rogelio.
FM02 with MicroRDS unit
			By rfallatt
FM02
			By rfallatt
FM02
			By rfallatt
FM02
			By SamJ435.
			By SamJ435.
			By pcoshatt
FM02
			By pcoshatt
FM02
			By hasoon
FM02 with Wall Wart Tamer
			By hasoon
			By jduawa
FM02
			By jduawa
FM02
			By Howards9
FM02
			By Howards9
FM02
			By idleup
FM02
CableGuard CG-1000 Demarcation Enclosure Customized for FM-02 transmitter and accessories with power switch assembly SLM2596 Buck Converter Step Down Power Regulator and Conditioner (3v to 40v) BH1415 Sound Quality Improvement Modification (modifies 19Khz pilot tone level to reduce hum and improve sound quality) Wall Wart Power Pack (I used one from an old dust buster, the SLM2596 will allow you to use any adapter 3v to 40v for your input power) -
			By idleup
FM02
			By nuelemma
FM02
A project box installation -
			By nuelemma
FM02
			By griffixdc
FM02
this is my fm02 in its enclosure i made 2 years ago..i used a dsl phone filter box ...its perfectly small -
			By griffixdc
FM02
			By CaptainMurdoch
FM02
Here are a few pics of my 10-minute, $0.50 from-a-garage-sale case. -
			By CaptainMurdoch
FM02
