Different Styles of Pixels
Revision as of 20:59, 17 August 2013 by Jklingert (talk | contribs) (Intro)
Pixels are RGB Light Emitting Diodes (LEDs) that allow a rainbow of individual colors to be created independently on each Pixel node. Pixels are Intelligent LEDs and have both power and control signals fed to each individual Pixel node. Using various communications protocols they are connected to Pixel Controllers that sends a specially formatted signal to the Pixel string that passes the control information to all of the Pixels connected in series. Each pixel uses 3 data channels to control it, one each for Red, Green and Blue.
  • Form Factor (String, Strip, Module, Etc.)
  • LEDs per meter (the spacing of the LEDs on the wire or strip)
  • ICs per Meter (Relates to how many LEDs are lit together for each Pixel, commonly 1 or 3 LEDs per IC)
  • Power Supply Voltage (typically 5VDC vs. 12 VDC)
  • Color Depth (The number of bits of data used to control each color such as 4,6,8 12, etc. bits)
  • LED Type (Size and Shape of LED which impacts overall brightness)
  • Waterproofing Technique (Injection molding, Cast Epoxy, Sleeve, Etc.)
  • Wire Size (The size of the wire connecting the Pixels together 18 AWG vs. 20AWG)
  • Pixel (IC)Control chips (WS2801, WS2811, TM1809, TM1824, GECE, Etc.)
  • Number of Wires Required (3 vs 4)
Pixel Properties
Form Factor
  • Strings - Can be any purchased in any custom length, but more then 50 pixels will require Power Injection. It important to remember that Pixel strings should never be strung using their wire to support them like you would with regular light stings. This will damage the Pixels and their waterproofing. Since they are generally custom made, you can request your vendor to make the spacing between units to custom lengths. Common methods to support Pixel strings include using cable ties or electric tape to attach them to PVC pipe, EMT electric conduit or Plastic Strapping. Strings are commonly used to make Megatrees, Minitrees and Leaping Arches.
    1. 12mm pixel - This is the most common Pixel type. They are often referred to as Bullet Shaped. It actually contains a 8mm LED inside the housing. The 12mm refers to the outer diameter of the package. These were orginally designed to mount inside of enclosures and are used for large advertising display screens.
    2. 12mm pixel (square) - These pixels can come with the wire coming either out of the back of the Pixel or the side of the Pixel. There has been some issues with the silicone injection molded units that have the wires coming out of the side not sealing and allowing water into the pixels.
    3. Pixels with Lens - There are a variety of Pixels available with Plastic Lens mounted on the RGB LED to make them look closer to a traditional C7 or C9 incandescent light. Common models include the Ge Color Effects (GECE), the Pixabulb by diyledexpress.com, the Cosmic Color Bulbs by Lightorama.com and the Technicolor Pixel by Ray Wu. Vendors like Ray Wu also sell Plastic lens that can be glued onto regular 12mm Pixel strings to achieve a similar look.
    4. Other Shapes - There are an assortment of other shapes including spheres, domes, boxes, etc. available from various vendors.
  • Strips - Are long flat flexible PCBs that have the RGB LEDs and the IC mounted directly on them and there is no wire between the Pixels other than the PCB. They generally come in 5M lengths. Depending on the Pixel IC used, from 1-3 RGB LEDs will light for each Pixel, so they can end up looking more like Dashes (- - - -) when there are 3 RGB LEDs per Pixel vs. Dots (.. . .) when there is 1 RGB LED per Pixel. Many strips can be cut shorter, but you must only cut at the marks on the strip identifying where they are cutable. You may have to solder wires to the PCB if you are doing Power Injection or cutting the strips. It is very helpful to use flux and a smaller soldering iron so you do not damage the delicate pads on the flexible PCB. Strips are commonly used to make Pixel Matrix on Flat Surfaces or as outlines around doors and windows.
    1. Bare board -These are uncoated and have no waterproofing and can not be used outdoors.
    2. Hollow Tube - This is the most common Pixel Strip. They are basically the uncoated Bare Board Pixel Strip pulled into a hollow Silicone Tube. You must use some form of Waterproofing like neutral cure GE Silicone II to seal the ends where the wires attach to the PCBs.
    3. Coated Strips - The bare PCBs are also available with a variety of waterproofing compounds. You need to scrape away the waterproofing compound to solder the wires to the PCB to power them or to cut them.
      • Silicone Coating - These strips are a little more flexible then the Epoxy Coated strips.
      • Epoxy Resin Coating
    4. Solid Tube - The bare PCBs are also available in hollow tubes that have been filled with various waterproofing compoounds.
      • Solid Silicone
      • Solid Epoxy Resin
  • Modules - Are very similar to strings, but are designed to be mounted to some surface and often have mounting tabs. They commonly have multiple RGB LEDs per pixels, so they are brighter then regular strings. Most are designed to run on 12VDC. Since they are generally custom made, you can request your vendor to make the spacing between units to custom lengths. They are frequently waterproofed by filling then with epoxy. They can come in metal or plastic housings. Modules are frequently used for lighting tune to signs, outline large objects and backlight Coro designs.
    1. Square With 4 RGB LEDs
    2. Rectangular - With 3 RGB LEDs
    3. Other Shapes - Many vendors also have a variety of other shapes available.
RGB LEDs per meter
  • Strips - Many 12VDC strips have 3 LEDs wired together as one pixel and the individual LEDs are not controllable, just the group of three.
    1. 30 LED/m - This is a common spacing and generally will result in a 5M strip with 50 individually controlable pixels and a total of 150 RGB LEDs.
    2. 60 LED/m - When you move up to higher density spacing, you often end up with shorter (4M) strips due to the power requirements. It is common to have to use Power Injection on strips with higher density.
  • Strings - Strings come in all different shapes and sizes of Pixel nodes. On common 12mm Pixel nodes there is only one RGB LED in each node, while some of the other shapes and modules often have multiple RGB LEDs inside.
    1. 10 LED/m - The most common spacing for 12mm Pixel strings is 100mm ( ~4") between the individual Pixel nodes. Since most Pixel strings are custom made, it is possible for a small change in price to change the Pixel spacing as a custom order from many vendors.
    1. 5VDC - The most common voltage for Pixel strings.
    2. 12VDC - The most common voltage for Pixel Strips and Pixel Modules. Many of the newer Pixel Control IC types like the WS 2811 and the WS2812 are now commonly found in 12VDC Pixel Strings as well.
    3. Other Voltages - Some Pixels are also available in 24VDC and 48VDC, but there are only a few models sold. These are typically Pixel Modules.
LED Type
    1. 3528 - These are surface mount LEDs that are each 3.5mm x 2.8mm. These are the smaller of the two surface mount LEDs and are noticeably dimmer then the larger 5050 LED. These are frequently found in strips and modules and some strings like the GECE.
    2. 5050 - These are surface mount LEDs that are each 5.0mm x 5.0mm This is the most common LED used in strips and modules and some strings like the Pixabulb (which has two LED per bulb!). They are quite a bit brighter than 3528 LEDs. Some of the newer IC types like the WS2812 have the 5050 mounted directly on top of the Control IC.
    3. 8mm - This is the type of LED typically used in 12mm and Square Pixel strings. Due to the plastic diffusion lens on the LED, they do a good job in dispersing the light in all directions.
Waterproofing
    1. Injection Molded Silicone - These units have the wires coming out of the back or side and the biggest issue has been the failure of the silicone used to seal to the wires. Many early pixels had obvious areas where water could easily get into the Pixels. While many of the newer unts have better sealing, there is always the potential for the water to wick in along the wires if there is any stress on te wires due to wind pulling on the wires.
    2. Cast Epoxy Resin in Sleeve - The most recent Pixels now come with the Pixels located in a plastic sleeve that is filled with a solid epoxy material. The hard epoxy seals well to the wires and many believe that results in a more waterproof pixel compared to Silicone Injection Molded Pixel strings.
    3. Cast Epoxy Resin coated PCB - This is the most common method of sealing Pixel Modules and many of the newer Pixel strings with Lens on them like the Pixabulb. These units have had good success in not failing in the weather.
    4. Silicone Tube - Most Pixel strips come with some form of Silicone Tube on them.
      1. Hollow Tube - These tubes must be sealed on the ends with a neutral cure sealant like GE Silicone II to prevent water from leaking in from the ends. They are also vulnerable to cuts and tears from items bumping into them and cutting thru the walls of the tubing.
      2. Silicone Filled Tube - These strips are made using the same silicone tube, but are filled with silicone at the factory to make a solid unit. The solid silicone provides a better light dispersion, acting sort of like a lens. You must cut and scrape thru the silicone to solder wires on to the PCB inside.
    5. Coated Strip - There are a number of cast coatings that can be applied directly tot he bare PCB at the factory. There has not been a lot discussed about how these strips hold up under weatehr either good or bad. They are just not as common as Pixels, but there are quite a few Dumb RGB strips that use this approach to weatherproofing.
      1. Silicone Coated Strip - This is the easier of the two to bend and shape due to the softer silicone coating.
      2. Epoxy Coated Strip - These strips tend to be stiffer and a little harder to remove the epoxy coating to access the PCB when soldering wires to cut lengths.
Wire Size
    1. 18 Gauge wire - This is the trend in many newer Pixels. The thicker wire allows for either longer distances or more pixels to be connected in a row. Most vendors will make any Pixel with the larger wire for a small fee. You should always use 18AWG wire.
    2. 20 Gauge wire - This is common on older Pixels and many low cost Pixels. The thinner wire is lower cost and can drop the cost of the Pixel strings slightly. It is common to have to add Power Injection on Pixels with 20 AWG wire.
  • Number of Wires Between Pixels
    • 3 wire - The three wires are: V+,GND,Data. Three wire Pixels can generally go longer distances between the first Pixel and the Pixel Controller. Most of the newer IC Types use 3 wires.
    • 4 wire - The four wires are: V+,GND,Data,Clock. Due to the Clock signal fading, you are often limited to only a few feet (<20ft) from the Pixel Controller to the first Pixel in a string without having to use Null Pixels. The cost of the extra wire makes 4 wire Pixels slightly more expensive. Many of the older IC Types use 4 wires.
  • Color Depth - The number of bits of color information used by the IC Type determines the Number of discrete colors you can make with the Pixel. Higher bit counts allow smoother fades and allows more colors to be generated.
    • 4 bit - Allows 16 shades of each primary color, or a total of 4,096 discrete colors. This is mainly the GE Color Effect (GECE) Pixels
    • 5 bit - Allows 32 shades of each primary color, or a total of 32,768 discrete colors. These are mainly older early pixels like the 6803.
    • 7 bit - Allows 128 shades of each primary color, or a total of 2,097,152 discrete colors. This is mainly the older 8806 Pixels.
    • 8 bit - Allows 256 shades of each primary color, or a total of 16,777,216 discrete colors. These are the most popular and common Pixel types. This includes the popular WS2811 Pixels.
    • >8 bit - There are specialized ICs that allow even higher bits per color, They are frequently used for video display screens. However, the common Controllers and the E1.31 communications protocol only support 8 bit data streams. Some controllers can make use of the additional data bits by using a function called Gamma Correction. This allows the controller to generate a more linear color signal near the bottom end of the dimming curve.
  • Number of Channels - Most IC types can only control 3 channels, so you need 1 IC for each RGB Pixel if you want individual control. Other ICs like the TM1809 can control 9 cannels, or 3 RGB Pixels. ICs like the TM1809 are popular in Pixel Strips where you want individual control of all of the RGB LEDs. To use other 3 channel ICs you either have to have 1 IC per RGB LED or you light up multiple RGB LEDs per IC, as is common on 12VDC Pixel Strips.
  • The Controller - Not all Controllers can drive all IC types. Many low cost controllers only support a limited subset of Pixels.
  • Maximum # of Pixels - Some Pixels like the GE Color Effects (GECE) are limited to maximum number of Pixels you can string in a row due to their unique communications protocol.
  • Refresh Rate - Some Pixel types can change color more rapidly than other types. This is a function of what your Pixel Controller supports. Common Refresh rates include 400 and 800kHz.
      • MY9941 - 4 wire (can drive 4 channels via Native DMX) Datasheet (English)
      • MY9942 (Native DMX)
      • MY9943 (Native DMX)
DIYLEDEXPRESS
String WS2801 50 pixels (6m) 5vdc 10 10 link $26.00 $0.52 IP68, cast epoxy in sleeve
String WS2811 50 pixels (6m) 5vdc 10 10 link $24.25 $0.49 IP68, cast epoxy in sleeve
String (C9) WS2811 50 pixels (*m) 12vdc 3-10 3-10 link $45.00 $0.90 IP68, C9 lens with 2x5050LEDs, available with 4",6",8",10",12" spacing PIXABULB
String (Square) WS2811 50 pixels (6m) 12vdc 10 10 link $25.75 $0.52 IP68, back wire, cast epoxy
Module (Rectangular) WS2811 20 pixels (2m) 12vdc 10 10 link $16.75 $0.84 3 LEDs, cast epoxy
HolidayCoro.com
String WS2811 50 pixels (33ft) 12vdc 4 4 link $35.99 $0.71 IP68, Optional C9 lens, 8" spacing, 6ft leader cable, attached waterproof connectors
Light-O-Rama (LOR)
(USA Based)
Ray Wu
(China Based)
String WS2811 50 pixels (5m) 5vdc 10 10 link $14.00 $0.28 IP68/66? with Black Wire (Injection Molded Silicone)
String WS2811 50 pixels (5m) 12vdc 10 10 link $30.00 $0.60 IP68, with 3 pin waterproof connectors, "Technicolor", lens covers are extra, 20ga wire
Strip WS2811 50 pixels (5m) 12vdc 30 10 link $30.00 $0.60 silicone tube
Strip WS2812 320 pixels (5m) 5vdc 64 64 link $77.00 $0.24 silicone tube, WS2811 with integrated 5050 LED
Matrix WS2812 256 pixels (17cm2) 5vdc ** ** link $65.00 $0.25 NOT WATERPROOF, WS2811 with integrated 5050 LED attached to flexible panel
Strip DMX 50 pixels (5m) 12vdc 30 10 link $66.32 $1.33 IP65, silicone tube
Retail Store (i.e. Lowes)
String GECE 25,36,50 pixels (20,29,41ft) 5vdc 4 4 link ~$2 G35 Cover, General Electric Color Effects (with controller and Power Supply)
Seasonal Entertainment
String WS2801 42 pixels (4.2m) 12vdc 10 10 link $32.00 $0.76 IP68, Rainbow Mini Pixels
String (C7) WS2801 42 pixels (8.4m) 12vdc 5 5 link $43.00 $1.02 IP68, Rainbow C7 Pixels
String (C9) WS2801 42 pixels (8.4m) 12vdc 5 5 link $45.00 $1.07 IP68, Rainbow C9 Pixels
Strip WS2801 42 pixels (4.2m) 12vdc 30 10 link $73.99 $1.76 IP68, Silicone filled, Rainbow Ribbon
Matrix WS2801 42 pixels (0.15x0.18m) 12vdc xx xx link $35.00 $0.83 Not Waterproof, Rainbow Matrix
Stellascapes
String (Stella-green) SS-1 85 pixels 5vdc 10 10 link $168 $1.98 bullet or flat packages
String (Stella-black) SS-1 85 pixels 5vdc 10 10 link $240 $2.82 bullet or flat packages
DIYLEDEXPRESS
HolidayCoro
String None 50 nodes (5m) 12vdc 10 0 link $32.50 $0.65
Strip None 5m 12vdc 30 0 link $49.99 $10.00/m silicone tube and coating
Module (rectangular) None 20 nodes 12vdc 10 0 link $25.80 $1.29 3 LEDs
Module (square) None 20 nodes 12vdc 10 0 link $27.80 $1.39 3 LEDs
Ray Wu
(China Based)
String None 50 nodes (5m) 12vdc 10 0 link $19.00 $0.38 IP68
String (square) None 50 nodes (10m) 12vdc 5 0 link $38.99 $0.78 IP68, RGB C7 lens
String (square) None 50 nodes (10m) 12vdc 5 0 link $39.99 $0.80 IP68, RGB C9 lens
Strip None 5m 12vdc 30 0 link $38.50 $7.70/m IP68, Silicone filled
Ray Wu
(China Based)
String None 50 nodes (5m) 5vdc 10 0 link $0.15 $0.15 IP68 WHITE ONLY NOT RGB
Waterproofing Pixels
Null Pixels
