Different Styles of Pixels
Revision as of 05:28, 27 July 2013 by Jklingert (talk | contribs) (Intro)
  • Form Factor (String, Strip, Module, Etc.)
  • LEDs per meter (the spacing of the LEDs on the wire or strip)
  • ICs per Meter (Relates to how many LEDs are lit together for each Pixel, commonly 1 or 3 LEDs per IC)
  • Power Supply Voltage (typically 5VDC vs. 12 VDC)
  • Color Depth (The number of bits of data used to control each color such as 4,6,8 12, etc. bits)
  • LED Type (Size and Shape of LED which impacts overall brightness)
  • Waterproofing Technique (Injection molding, Cast Epoxy, Sleeve, Etc.)
  • Wire Size (The size of the wire connecting the Pixels together 18 AWG vs. 20AWG)
  • Pixel (IC)Control chips (WS2801, WS2811, TM1809, TM1824, GECE, Etc.)
  • Number of Wires Required (3 vs 4)
There are many options and configurations and each has it's advantages and disadvantages depending on the application. Some of the most popular Pixels are ones driven by the WS2811 IC and use 12VDC power. They are a good balance of new technology and reliable designs.
Pixel Properties
Form Factor
  • Strings (Can be any length, but more then 50 pixels will require power injection)
    1. 12mm pixel
    2. 12mm pixel (square)
  • Strips (Usually 5M length)
    1. Bare board (no waterproofing)
    2. Hollow Tube
    3. Coated Strips
      • Silicone Coating
      • Epoxy Resin Coating
    4. Solid Tube
      • Solid Silicone
      • Solid Epoxy Resin
  • Modules
    1. Square
    2. Rectangular
LEDs per meter
  • Strips
    1. 30 LED/m
    2. 60 LED/m
  • Strings
    1. 10 LED/m (100mm spacing between nodes is common )
    1. 5VDC
    2. 12VDC
    3. 24VDC
LED Type
    1. 3528 surface mount (3.5mm x 2.8mm) (typically used in strips and modules)
    2. 5050 surface mount (5.0mm x 5.0mm) (typically used in strips and modules)
    3. 8mm (typically used in strings)
Waterproofing
    1. Injection Molded Silicone
    2. Cast Epoxy Resin in Sleeve
    3. Cast Epoxy Resin coated PCB
    4. Silicone Tube
      1. Hollow Tube
      2. Silicone Filled Tube
    5. Silicone Coated Strip
    6. Epoxy Coated Strip
Wire Size
    1. 18 Gauge wire (Thicker, better for longer distance or more pixels)
    2. 20 Guage wire
      • MY9941 - 4 wire (can drive 4 channels via Native DMX) Datasheet (English)
      • MY9942 (Native DMX)
      • MY9943 (Native DMX)
DIYLEDEXPRESS
String WS2801 50 pixels (6m) 5vdc 10 10 link $26.00 $0.52 IP68, cast epoxy in sleeve
String WS2811 50 pixels (6m) 5vdc 10 10 link $24.25 $0.49 IP68, cast epoxy in sleeve
String (C9) WS2811 50 pixels (*m) 12vdc 3-10 3-10 link $45.00 $0.90 IP68, C9 lens with 2x5050LEDs, available with 4",6",8",10",12" spacing PIXABULB
String (Square) WS2811 50 pixels (6m) 12vdc 10 10 link $25.75 $0.52 IP68, back wire, cast epoxy
Module (Rectangular) WS2811 20 pixels (2m) 12vdc 10 10 link $16.75 $0.84 3 LEDs, cast epoxy
Light-O-Rama (LOR)
(USA Based)
Ray Wu
(China Based)
String WS2811 50 pixels (5m) 5vdc 10 10 link $14.00 $0.28 IP68/66? with Black Wire (Injection Molded Silicone)
String WS2811 50 pixels (5m) 12vdc 10 10 link $30.00 $0.60 IP68, with 3 pin waterproof connectors, "Technicolor", lens covers are extra, 20ga wire
Strip WS2811 50 pixels (5m) 12vdc 30 10 link $30.00 $0.60 silicone tube
Strip WS2812 320 pixels (5m) 5vdc 64 64 link $77.00 $0.24 silicone tube, WS2811 with integrated 5050 LED
Strip DMX 50 pixels (5m) 12vdc 30 10 link $66.32 $1.33 IP65, silicone tube
Retail Store (i.e. Lowes)
String GECE 25,36,50 pixels (20,29,41ft) 5vdc 4 4 link ~$2 G35 Cover, General Electric Color Effects (with controller and Power Supply)
Seasonal Entertainment
String WS2801 42 pixels (4.2m) 12vdc 10 10 link $32.00 $0.76 IP68, Rainbow Mini Pixels
String (C7) WS2801 42 pixels (8.4m) 12vdc 5 5 link $43.00 $1.02 IP68, Rainbow C7 Pixels
String (C9) WS2801 42 pixels (8.4m) 12vdc 5 5 link $45.00 $1.07 IP68, Rainbow C9 Pixels
Strip WS2801 42 pixels (4.2m) 12vdc 30 10 link $73.99 $1.76 IP68, Silicone filled, Rainbow Ribbon
Matrix WS2801 42 pixels (0.15x0.18m) 12vdc xx xx link $35.00 $0.83 Not Waterproof, Rainbow Matrix
Stellascapes
String (Stella-green) SS-1 85 pixels 5vdc 10 10 link $168 $1.98 bullet or flat packages
String (Stella-black) SS-1 85 pixels 5vdc 10 10 link $240 $2.82 bullet or flat packages
DIYLEDEXPRESS
HolidayCoro
String None 50 nodes (5m) 12vdc 10 0 link $32.50 $0.65
Strip None 5m 12vdc 30 0 link $49.99 $10.00/m silicone tube and coating
Module (rectangular) None 20 nodes 12vdc 10 0 link $25.80 $1.29 3 LEDs
Module (square) None 20 nodes 12vdc 10 0 link $27.80 $1.39 3 LEDs
Ray Wu
(China Based)
String None 50 nodes (5m) 12vdc 10 0 link $19.00 $0.38 IP68
String (square) None 50 nodes (10m) 12vdc 5 0 link $38.99 $0.78 IP68, RGB C7 lens
String (square) None 50 nodes (10m) 12vdc 5 0 link $39.99 $0.80 IP68, RGB C9 lens
Strip None 5m 12vdc 30 0 link $38.50 $7.70/m IP68, Silicone filled
Ray Wu
(China Based)
String None 50 nodes (5m) 5vdc 10 0 link $0.15 $0.15 IP68 WHITE ONLY NOT RGB
