Hardware Design Guidelines
This is the area we, the DIY community, will list some general Hardware Design Guidelines for circuit boards and electronic devices.
Benefits of following the guidelines
We have come into some situations where some boards are using a different standard then others, thus causing confusion when populating a board or making some SSR assemblies incompatible with controllers.  Normally this would not be a problem, but we are finding these things out after the fact. It causes a scramble to try and get it all to work properly.
Another benefit of following these guidelines is it will allow other to acquire the appropriate tools for assembly, if required, and they will be used continually instead of a one-time deal.  Also we will be able to stock up on parts should we need to make a repair or have enough on hand to populate another board of some kind.  We will also be able to purchase a larger quantity of certain parts to receive price breaks in anticipation of future population. This will save all of us money in the long run.
Using these guidelines
These are only guidelines and should not be treated as gospel. We ask you to adhere to these guidelines when designing new PCB's if you can. If you need to deviate from these guidelines we ask that you specify the deviation in your assembly notes and list them when releasing your design. This way, others will know if there are any compatibility issues. If you are populating a circuit board please double check to make sure these guidelines were followed before you start populating your board based on what you read on this page.
PCB Design
- Leds should be placed with a square pad as the cathode.
 - Diodes should be placed with a square pad as the cathode.
 - Power Connectors should be placed with a square pad as the ground.
 - Capacitors should be placed with a square pad as the positive pin.
 - Resistor lead spacing should be .400" unless required otherwise.
 - Pads on the PCB should be .056" diameter with .029" hole, unless otherwise required.
 - Mounting holes should be .300" diameter with .167" hole. There should be a minimum of 3 mounting holes per board. This size hole will fit a 6/32 screw nicely.
Pinouts
Controller Output (SSR Input)
RJ45 controller outputs should be pinned out as follows:
Pin 1 - +5v supply
Pin 2 - Channel 1 output
Pin 3 - reserved
Pin 4 - Channel 2 output
Pin 5 - reserved
Pin 6 - Channel 3 output
Pin 7 - Ground
Pin 8 - Channel 4 output
595 Style Controllers: Inputs
595/Grinch Controller RJ45 inputs should be pinned as follows:
Pin 1 - Power (optional)
Pin 2 - no connection
Pin 3 - Ground
Pin 4 - no connection
Pin 5 - Clock
Pin 6 - no connection
Pin 7 - Data Latch
Pin 8 - Serial Data In/Out
Renard Controllers: Inputs
Renard Controller RJ45 inputs (all pins should be connected straight through on controllers):
Pin 1 - Ground
Pin 2 - Ground
Pin 3 - alternate zero-cross input
Pin 4 - Data-
Pin 5 - Data+
Pin 7 - Power input (preferably pulsing DC to allow use as both power and zero-crossing source)
Pin 8 - Power input (preferably pulsing DC to allow use as both power and zero-crossing source)
DMX Controllers: Inputs
DMX Controller RJ45 Inputs (per ESTA):
Pin 1 - Data1+
Pin 2 - Data1-
Pin 3 - Data2+
Pin 5 - no connection
Pin 6 - Data2-
Pin 7 - Link Common for Data1
Pin 8 - Link Common for Data2
Power Input Connectors
Power Connectors
Pin 1 - Ground
Component Selection
Through-hole parts
Through-hole parts are preferred for coop boards, due to the difficulties in handling and soldering surface-mount components.
Power Connectors
Power Connectors
Molex SL Series headers for low voltage/amperage applications.  .100 pad spacing.  Example Mouser part number : 538-70543-0037
Molex SL Series plugs for low voltage/amperage applications.  .100 spacing.  Example Mouser part number : 538-50-57-9403
Molex connector terminals for low voltage/amperage applications.  Example Mouser part number : 538-16-02-0102
Jumpers/Headers
Headers
Headers for jumpers due to design/configuration options.  any .100 pad spacing header so a standard jumper can be utilized.
Integrated Circuits
IC's
Sockets should be utilized on all IC's.  This will prevent overheating of the IC's and ease of replacement if required.
Fuses should be 5x20mm unless otherwise required.
Screw Terminals
Terminals
Screw Terminals should have a 5.08mm lead spacing.  Example Mouser part number : 571-2828374
