Electronics Hardware
Revision as of 11:35, 11 December 2007 by TED (talk | contribs) (Lynx)
This is the page to contribute content about the electronics hardware you use to run your display. If it electronic components or solder then it belongs here. Anything from relays and controllers to pic programmers and power supplies.
Links
Hardware Design Guidelines A DIYC community standardization
Co-Op Boards and Assembly Instructions
Comparison of DIY Boards
Renard Main Page Simple PIC-Based Light Dimmer Controller for use with Vixen
Solid State Relays
DMX to Grinch/595 convertor: How to make your Grinch speak DMX
All In One Tester : A single unit for testing controllers, cables, and SSR's
Olsen 595 : How to make an Olsen 595 controller at home
DMX ROBO Spot Light: How to build a Robotic Full Color Spotlight.
This section provides information about Do-It-Yourself (DIY) hardware that works with the Vixen software program. This is a Windows (.NET2) program that runs on a PC, and is used to create and run light shows that may be synchronized to music. Here is a brief list of the DIY approaches that you can take that will work with Vixen.
Parallel Port Approaches
These controllers only work with parallel ports that are built into the PC (and also older ISA Parallel Port cards). People have had difficulty getting them to work with PCI Parallel Port cards or USB-Parallel converters.
SSR Direct Attach
If you need 12 or fewer channels, you can just buy or build SSRs and connect them to the parallel port on your PC, and use them to turn 110VAC light strings (or just plain lamps) on and off (no dimming). From time to time there are coop buys of SSR boards and/or parts, so reduce your expense.
Kit74
Hill320
Olsen 595/Grinch
There are some variations of this approach that support dimming, but they are not as popular and there aren't any coop boards available.
Ledtriks
Serial Port Approaches
There are several controller designs that can be interfaced through the serial port (including USB-Serial converters). These designs support dimming, and are microcontroller-based designs (exclusively PICs so far). These designs are typically more complex than the Parallel Port designs
Firegod
This is a modular system that supports 32 to 128 channels per serial port, in increments of 32 channels, with 100 levels of dimming (using pulse width modulation - PWM). It consists of a host controller module and one to four field modules. The SSRs are not included on these boards, and must be provided separately. The interface to this system is RS485, so a USB-RS485 (or RS232-RS485) converters are required. This system is available on a coop basis from time to time, with the kits including the boards, the parts, and pre-programmed microcontroller chips (PICs). This board is intermediate in complexity to build.
Renard
rgbLED
TBA
DMX Approaches
JEC Pixel Displays
Lynx
The Lynx is a DIY dimmer design that uses DMX as its protocol but uses standard Cat5 cable for interconnections. It's designed to be similar to the commercially available dimmers (LOR,AL,ETC) layout and is an all in one unit that has its own power supply and ssr's built into it. You connect your DMX Cat5 and plug it in. Lights plug into female cord connections that exit from the board. It allows for a full 256 levels of dimming. The starting address is programmed via vixen. Since it uses the DMX protocol you can run 512 channels of Linx on one DMX universe at 25ms timming.
