Creating a Sequence:
Creating a Sequence
HLS Sequence Creation Wizard (13F)
Setting up the Sequence File:
Setting up the Audio File:
Time Resolution (13F)
The Time Resolution must be set before you setup any channels.  Once it has been set, you cannot change it again.  The default time resolution is set for 50 milliseconds.  You can also choose a 25 millisecond or 100 millisecond time resolution. The time resolution sets how frequently effect changes can occur on a channel.
- 25 msec: This provides 40 timing grid spaces for every second.
 - 50 msec: This provides 20 timing grid spaces for every second.
 - 100 msec: This provides 10 timing grid spaces for every second.
- A higher grid resolution will result in more channels displayed on the screen at one time and more timing marks on display at one time, but the disadvantage is that the grid squares are smaller.
 - A lower grid resolution will result in larger squares which are easier to see, but the disadvantage is fewer channels and timing marks on the screen at one time.
