Sequencing Channels and Adding Effects:
Creating Basic Effects (12Z)
The HLS Sequencing Window has four basic components which are important when sequencing (See Figure 5-1).
Selection Mode in HLS
Basic Method to Create a Selection Box:
Basic Effects
Level:
- Shortcut key: L
Ramp Up:
- Shortcut key: U
Ramp Down:
- Shortcut key: D
Modifying Effects
Moving Effects:
Deleting Single Effects:
Deleting an Area of Effects:
Copy/Paste Effects:
Modify Effect Attributes:
Adding and Using Beat Tracks (12Z)
HLS supports creating beat tracks in a couple of ways.  One way is to manually press a button or click a mouse while a song is playing to set the beat.  Another way would be to apply a filter to the audio and then manually "turn on" the beat track at points identified through the filter.
Add Beat Track Channels
First, channels must be added so you can use them as beat tracks.
Setting Display Group for Beat Track
 - Create a Display Group named "Beat" and add all three channels (See Figure 5-6).
Beat Track From Clicks
Creating a Beat Track from Clicks is one of the easiest ways to create a Beat Track. Clicks must be quick and not everything will line up perfectly, but it can give reasonably good results.
- Activate the Beat Track by clicking Manage Channels -> Select a Beat Track Channel.
 - Select the Beat Track you want to use and click OK (See Figure 5-7).
- Check the box Beat Track Active to let HLS know that you are planning to record clicks for a beat track (see Figure 5-8).
 - Press the CTRL key or the Left Mouse button at each beat in the song.
- When the song is complete, there will be two grid cells filled in at every click received. Your beat track has been created. (See Figure 5-9)
Beat Track from Filters
This is a very powerful feature of HLS and one that can come in handy when setting up beat tracks. You get to this by clicking Audio File -> Apply Lo or Hi Pass Filter or Band Pass. The DSP Filtering window will open (See Figure 5-10).
- Wikipedia: High Pass Filter
- Wikipedia: Low Pass Filter
 - Band Pass filter: This filters on BOTH high and low frequencies.  The Frequency value is the "desired" frequency.  A band pass filter will filter OUT both the high and low frequencies that are further away from that frequency.
- Wikipedia: Band Pass Filter
Applying the Filter:
- Choose the filter you wish to use, enter the needed information, and click OK. You can also use the "Stay Here" option to apply the filter and continue working with the audio without closing the Filtering window. (See Figure 5-11a and 5-11b for an example of the audio before and after applying an 8 khz filter to attempt to isolate a cymbal sound.)
- Once the sound has been isolated, manually add effects where the sound is present. In the example, Beat Track 2 is being used to mark two cells with a Level effect at each cymbal sound (see Figure 5-12).
- Tip: To speed up this process, you may find that using the CLICK filter AFTER applying the DSP filter will allow you to click accurately with the sound you want isolated rather than manually drawing in the effects.
- Once finished with the filter, return the audio to normal by choosing Audio File -> Remove Filter.
Common Sound Frequencies:
Cleaning up a Beat Track
 - When the timing mark is placed where you want it, click on it again (or press escape) to exit selection mode.
Setting Defaults for Effects (12Z)
Choose the Defaults tab on top of HLS and select the item you would like to set defaults for. For this example, Ramp Up was selected. The screen shown in Figure 5-13 will appear. You can change any values you would like and they will be saved as the new default values for the current sequence.
Creating Chase Effects (12Z)
A chase effect is an effect that spans multiple channels with a lighting effect that moves through those channels over a period of time. When it is set to lights, it creates an appearance of a "chase" through lighting channels. Chases can be created manually in HLS, or, through an Action menu to chase a group (the easy way).
Manual Chase
- For illustration, we will be adding a chase to eight channels. First, add the effect you want to chase to each of the eight channels. This can be level, ramp up, ramp down, or any other effect for a single channel. (See Figure 5-14 for an example where Ramp Up was chosen to run over 8 cells in each channel.)
- Next, slide each channel effect to create the chase. This is done by clicking on the left-most cell on channel 2 first, then moving the mouse to the right. All channels in the effect will slide to the right. The same procedure is to be used for the rest of the channels. The results are shown in Figure 5-15.
Chase (The Easy Way)
- For illustration, we will be adding a chase to eight channels. First, add the effect you want to chase to each of the eight channels. This can be level, ramp up, ramp down, or any other effect for a single channel. (Look up to Figure 5-14 for an example where Ramp Up was chosen to run over 8 cells in each channel.)
- Next, select the cells in all eight channels that you want to chase. (Remember to CTRL-Left click the left-most cell to let HLS know you want to select instead of move.)
 - Once the selection-box is complete, Right-click the group of cells and select Perform Action on Selected Group.
 - In the menu that opens, select Chase Group and click OK (see Figure 5-16).
- Click in one of the corners and move the mouse to pull the channels apart into a chase formation.
 - When satisfied with the result, left-click again and hit ESC (Look up to Figure 5-15 to see end result).
 - Tip: BOTH methods can create the SAME end result. However, the built in chase function is much faster.
Video: Chase Effects
Mirroring Effects (12Z)
Mirroring is taking an effect or group of effects,and flipping them horizontally or vertically.
The following image demonstrates the sample channels which will be used to mirror.
Horizontal Mirror:
- Enter Selection mode and select the group of effects to mirror (See Figure 5-17).
 - Note: Remember, to select effects, you must CTRL-left-click.
 - Right-click on the group and press CTRL+H or select Flip Horizontal Selection Box (see Figure 5-18).
 - Tip: If you create a selection box longer than the object to be flipped, HLS will flip and move it to the right-most cells.
Vertical Mirror:
- Enter Selection mode and select the group of effects to mirror.
 - Right-click on the group and press CTRL+M or select Flip Vertical Selection Box (see Figure 5-19).
 - Tip: If you create a selection box taller than the object to be flipped, HLS will flip and move it to the furthest away cells.
Fill Effects (12Z)
Fill Effects "fill in" empty space with effect that "extends" the pre-existing effect. You can fill from specific directions to achieve the effect you want.
- Note: Fill Effects and Fill Channels are NOT the same thing. Fill Channels are used in conjunction with custom effects or pixel plane effects to fill in areas where the custom effect or pixel plane effect are off. Fill Effects are used in the same channel with your other effects to "fill in" the gaps.
- Figure 5-20 shows various ramp ups applied to some channels. A selection box has been drawn around a number of the effects.
- Right-click inside the selection box and choose Perform action on selected group (See Figure 5-21).
 - Click Fill to Left Side or Fill to Right Side, further explained below.
- Fill effects to the LEFT of the selection box will "stretch" all of the selected effects to the left until it reaches the left-most edge of the selection box. The empty spaces to the right will not be affected. See the result in figure 5-22.
- Fill effects to the RIGHT of the selection box will "stretch" all of the selected effects to the right until they reach the right-most edge of the selection box. The empty spaces to the left will not be affected. See the result in figure 5-23.
 - Tip: Note that in the second row, the Fill to Right command picked up on the Right-most effect contained in the selection box to fill. If your selection box contains more than one effect in a row, it will always fill using the one closet to the "fill edge."
Submaster Lighting Channels (12Z)
Template:Submaster Lighting Channels
Sequencing with RGB Channels (12Z)
RGB Channels are a special channel in HLS that consist of three output channels each. These would generally be used with RGB strings and display items, both "dumb" RGB and Pixels. However, they can also be used to reduce channel counts of "mega strings", or strings composed of three different color strands which are contained together in one.
RGB Channels in the Sequence Window
RGB Channels, when displayed in the sequence window, will place "RGB" in front of the HLS Channel name.  This helps distinguish which HLS channels are RGB channels.  When adding effects to RGB channels, HLS will use a white color by default.  Once you have added white effects, you can right-click on the effects, choose Modify, and change the color by clicking the white-colored rectangle in the modify effect window (see Figure 5-26).
Managing Color when Adding Effects
Effects for RGB channels work the same as effects for regular channels. The difference is the addition of the color variable. While the previous sub-section mentioned a way you can sequence all in white and add color later, HLS has built in tools to allow you to apply basic effects in the color desired.
In the HLS window, there are colored effect buttons for Level, Ramp Up, and Ramp Down. See Figure 5-27. When you first open a sequence, these are red.  The rectangle to the right of the buttons can be pressed which will open the Color Picker (See Figure 5-28).
- Click and open the Color Picker.
 - Select a color for the effect you wish to add.
 - Click OK to close the Color Picker and activate chosen color.
 - Select desired grid cells to apply the effect, then click the colored effect button.
 - Tip: Once you have clicked the colored effect button, you can now use the Keyboard Shortcuts to add additional effects to RGB channels. These effects will now be added with the picked color.
The HLS Toolbar
The HLS Toolbar is a floating toolbar that provides the use of several shortcuts when sequencing effects, including shortcuts that pertain to RGB channels. You can find out more about The HLS Toolbar and it's purposes.
- Change RGB Color Effects: Select RGB channel effects you wish to colorize. Click the large rectangle and select the desired color. Click the Change RGB Color Effects button and the selected effects will be changed to the desired color. Your effects and their values will remain the same.
- Chase RGB Vertical: Create a "color chase" on a vertical plane.
- Select multiple channels with pre-existing effects on a vertical plane.
 - Click the first of the two color blocks in the row.
 - Set beginning and ending colors for color wheel chase.
 - Click Chase RGB Vertical button to chase through the colors on the wheel vertically through the selected channels.
- Chase RGB Horizontal: Create a "color chase" on a horizontal plane.
- Select multiple cells of a pre-existing effect on a horizontal plane.
 - Click first of two color blocks in the row.
 - Click Chase RGB Horizontal button to chase through the colors on the wheel horizontally through the selected grid cells.
Custom Effects (12Z)
Introduction to Custom Effects
Custom Effects are a combination of multiple effects that can be applied to a sequence in a variety of ways. This creates a very custom yet clearly defined effect. This is one of the most powerful features of HLS. The first step is to create an effect template from defining an order of basic effects. Then, that template is applied to a selection box in a number of configurable ways to create the custom effect.
To create your first Custom Effect, click Effects -> Add a Custom Effect Group.
Building a Custom Effect Template
When you Add a Custom Effect Group, the Custom Effect window will open (see Figure 5-30).
- Click the Add an Effect button to add a row where you will enter your effect data.
 - Column Definitions:
- Type: General type of effect (level, ramp up, ramp down, specific?)
 - Length: the length of the effect in grid cells.
 - Start Value: Intensity value at the start of the effect. (active for ramps only)
 - End Value: Intensity value at the end of the effect. (active for ramps only)
 - Level Value: Intensity value of a level effect. (active for level only)
 - Specific Value: This sets a specific DMX value (0-255) rather than the normal behavior of percentage (0-100)
 - Reorder: Used when reordering the effects that make up the custom effect.
- Continue adding effects until you have completed your custom effect.
 - To remove an effect row, right-click on the left-most column (where the number appears).
 - To Reorder effects, Change the numbers in the reorder column.
 - Once you are satisfied with the components that make up your custom effect, type a name in the Name field and click OK (see Figure 5-31).
Placing a Custom Effect into a Sequence
Selecting Cells and the Custom Effect Template
Now that you have built your custom effect, you can use it in a sequence.
- Select the grid cells and channels on which you wish to place the custom effect.
 - Press the Custom button or C and a window will open for you to select the custom effect (see Figure 5-32).
 - Select your effect and click OK. This will open the Execution of Effect window.
Executing the Custom Effect
The Execution window (see Figure 5-33) is where you tell HLS very specifically how you want the custom effect applied. This is truly where the power and customization of HLS shines through.
The layout of the window contains basic information in the top left:
- The name of your custom effect template and it's size.
 - Selection Size X/Y: This is the number of grid cells selected (X), and the number of channels (Y) that you will apply the effect to.
Modifying the pattern of how the effect is applied:
- Random Coverage: This will place the custom effect randomly throughout the selection box. The %Coverage lets HLS know what percentage of the cells contained in the selection box should be covered by the effect.
 - Butted: This means the effects will be placed right next to each other. HLS will place your custom effect back-to-back in each selected channel all the way to the end of your selection.
 - Period: This will apply your custom effect every defined period of cells. This period is the "wait time" before the next custom effect is applied. For example, a period of 4 would apply your custom effect, leave 4 grid cells blank, then reapply the effect, and so on.
Additional Modifiers:
- Random Intensity: This will apply your custom effect using a random intensity, from your custom low value to high value.
 - Single Effect Only: This will apply your custom effect one time only, exactly as you defined it.
 - Chase - Single Event: This will draw your custom effect one time, and chase it through the channels contained in your selection box.
RGB Channels and Custom Effects
- If you wish your custom effect to be a color other than white, use the color-specified custom button on the toolbar.
 - Select the rectangle and choose the color you wish to use for the rgb channels. Click the color-coded custom button.
 - Configure your Custom effect as described in the sections above.
 - It will apply the custom effect in the color chosen.
Creating a Library of Group Effects (12Z)
Introduction to the HLS Library
HLS contains a Library function, which allows the user to save group effects into a library file which can then be inserted into other places in the sequence or in other sequences. An example would be of saving an group of channel effects that create a wave of colors across a set of mini-trees. This wave could be reused in other places or sequences without having to be created from scratch. A library can contain multiple group effects. HLS can also contain multiple libraries, such as one for mini-trees, one for arches, etc.
- To view the Library, click Library -> Just View - See What's Available. When done, click Cancel to close the window.
Creating a New Library
To begin, you must create a new library for HLS to store effects into.  To do this, click Library -> Make New Library from the top menu bar.  Type in a name for your new library and click OK (see Figure 5-34).
Saving Sequence Data to a Library
- Draw a selection box around the group of effects and channels that you would like to save to the Library.
 - Click Library -> Add Effect Group to Library to assign the selected effects to a library (see Figure 5-35).
 - Click on the name of the library you wish to save the group effect into. The bottom half of the window will show information about the effects being saved.
 - Note: Make sure Effect Grouping is selected and not Sequence Layout.
 - Name the group effect in the Description field and Click OK.
Inserting Saved Group Effects into a Sequence
- It is recommended to save your sequence before adding an effect.
 - To insert a saved group effect, click Library -> Insert into Sequence an Effect From Library.
 - In the Library window that opens, select the saved effect you wish to insert. It will become highlighted in green (see Figure 5-36). Click OK to continue.
- After clicking OK, HLS will display a warning message (see Figure 5-37).
 - To continue, click OK. Otherwise, cancel will abort the insertion of the group effect.
 - HLS will display another window with instructions on how to tell HLS where you want the effect inserted (see Figure 5-38).
 - Click Yes to continue.
 - Left-click on the cell you wish to paste the group effect into. The effect will be pasted starting at that point.
 - Once the effect has been inserted, you can then manipulate the individual effects as needed.
Removing a Library of Group Effects
- Currently, you cannot delete Group Effects or whole Libraries from within HLS.
 - A work-around to delete Libraries is to navigate using Windows Explorer to the folder that contains HLS.
 - Navigate into the Library folder.
 - Find the Library you wish to delete. It will have the .LIB extension and be named the same as the library inside HLS (see Figure 5-39).
 - Select the file and delete it. HLS will now no longer contain that library or it's associated group effects.
Depreciated Library Functions
In the past, the Library function could be used to save Channel Layout for a sequence. This would allow you to reuse a sequence's channel setup, output setup, etc. with other sequences. This feature has been depreciated in favor of Using HLS Sequence Images.
