Creating a PixelPlane
Current as of Version 12Z.
What is a PixelPlane?
VIDEO: Joe describes a PixelPlane and creating a PixelPlane in his HLS 2013 Intro video
How to Create a PixelPlane
- First, open the PixelPlane Manager (Manage Channels -> Manage PixelPlane Channels).
 - In the Select PixelPlane Channel window, press the NEW button to create a new PixelPlane (See Figure 6-1).
 - The Manage PixelPlane window will open (See Figure 6-2). Click Create PixelPlane AND Channels.
 - Note: In the past, PixelPlane Channels were first created in the regular Channel Manager. They are now created here. If you have already created channels (in the old way), or are importing from another file and want to convert channels to a pixel plane, select Create/Modify and select your channels manually and then save the changes.
- Assign the type of PixelPlane that you have and then click "Assign Type of PixelPlane."
- Note: Currently, only "Mega Tree" and "Vertical Matrix" are supported.
- Complete the fields to help HLS understand your PixelPlane object, then click OK (See Figure 6-4).
| Chapter 5: Sequencing Channels and Adding Effect | Chapter 6: Creating and Using PixelPlanes | The PixelPlane Editor |
