16 Channel Renard with SSR Assembly Instructions
- Assembly Time: 2 hours
 - Skill Level: Medium
Disclaimer
THIS FILE IS DISTRIBUTED IN THE HOPE THAT IT WILL BE USEFUL, BUT WITHOUT ANY WARRANTY; WITHOUT EVEN THE IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE.
Reference Material
Tools
- Bench Soldering Iron
 - Silver Solder
 - Flat cut dykes
 - Desoldering bulb
Other Requirements
- You will need an RS232 to RS485 converter. I would suggest EBAY
Related Documents/Links
- RS485 Converter from Ebay
 - Parts List
 - Theory of Operations
 - Image of Board
 - Top of PCB
 - Botton of PCB
 - Silk Screen
 - Latest PIC Code
Build Steps
| Install Item | Qty | Mouser P/N | Location | Notes |
| 1. IC sockets 6 pin | 17 | 571-3902611 | U3-U19 | Make sure they are oriented the same way as the silk screen image. U19 is oriented opposite of the others. |
| 2. IC Sockets 8 Pin | 2 | 575-193308 | U20 & U21 | . |
| 3. IC Sockets 14 Pin | 2 | 575-199314 | U1 & U2 | . |
| 4. Bossman Fuse Holder | 4 | 504-1a3399-10 | H1 & H2 pads | Make sure the notch on the fuse holder is oriented so one is on the top and the other on the bottom to properly hold the fuse. |
| 5. Euro Sytle Terminal Blocks | 11 | 538-398890-0302 | Lower Edge of Board | . |
| 6. 15Kohm resistors | 2 | 71-ccf60-15k-e3 | R17 & R18 | . |
| 7. 178ohm resistors | 16 | 273-178-rc | R1 - R16 | Orient the colored bands all the same way for ease of troubleshooting later. |
| 8. 10pin 680ohm bus resistor | 2 | 266-680 | above U7 & U15 | . |
| Numbered Photo - Numbers coorospond to the build steps | ||||
| 9. 2 ping jumper mount | 4 | 571-3-644456-2 | J1 - J4 | . |
| 10. Green LED | 2 | 604-wp7104gt | Ch2Diag #1 & #2 | The short leg of the led goes to the flat side of the silkscreening |
| 11. Monolithic Radial Capactor | 2 | 81-rpee41h105m4k1e12 | C1 & C2 | . |
| 12. Amp Modular Jacks rj45 | 2 | 571-5520251-4 | Upper Right and Left | . |
| 13. Coated axial ceramic capacitors | 2 | 80-c410c104m5u | C3 & C4 | . |
| 14. Voltage Regulator | 1 | 821-TS7805C2 | 5vReg | . |
| 15. 8 amp Triac | 16 | 511-BTA08-400b | Bottom of board | Be sure to solder these well as they will be carrying 110v A/C |
| 16. 1K ohm resistors | 3 | 660-mf1/4dc1001f | R20, R21 & R24 | . |
| 17. Crystal Clock oscillator | 1 | 520-tck1843-x | OSC1 | . |
| 18. 22k ohm resistor | 3 | 660-mf1/4dlt52r2702f | R19, R22 & R23 | . |
| 19. zener diod | 1 | 78-in5239b | D2 | . |
| 20. zener diode | 1 | 512-1n5229b-t50a | D1 | . |
| 21. 120 ohm resistor | 1 | 660-mf1/4dct52r1200f | R26 | . |
| 22. VR/50v diod | 1 | 625-1n4001-e3 | D3 | . |
| 23. red led | 1 | 604-wp7104ec | Top Center | . |
| 24. H11aa1 | 1 | 782-h11aa1 | U19 | . |
| 25. Rs485 | 2 | 837-isl81487eip | U20 & U21 | . |
| 26. Pic Chips | 2 | 11-11 | #2 | . |
| 27. fuses | 2 | 504-gma-5 | H1 & H2 | . |
| 28. Heat Sync | 1 | 532-574502B00 | 5vReg | . |
Still Entering Give me so time to finish before you edit this please
Options
240 or 24 volt Conversion
The original controller was designed for operation on 110VAC and many of the parts were specified for 110V. The board will operate at other voltages, however a number of changes need to be made.
The first decision to be made is what voltage you want to switch. The triacs are responsible for switching the primary voltage. The is no reason that the primary voltage for the TRIACs could not be 240VAC or 24VAC, however the circuit will need to be modified.
One of the major changes is the ZC detect section of the controller. The original circuit specified a H11AA1 for the optoisolator, with two 15k ohm 1watt resistors for current limiting. Details on the H11AA1 can be found here
I understand that the 15kohm values are calculated as follows:
I(fwd) = 5mA
V(rms) = 110 VAC RMS
V (peak) = V(rms) * 1.41 = 150VAC
R = V(peak) / I (fwd) = 150V / 0.005 A = 30k ohm Two resistors of 15 k each for a total of 30k.
P = I * R (squared) = 0.005 * (15000 * 15000) = 0.75W per resistor.
24VAC switching.
Parts Required and changes.
Gate Resistors - The original value for the gate resistors (item 7) was 180 ohms. For 24VAC operation, the gate resistors need to be changed to 33 ohms.
H11AA1 limiting resitors - These will need to be changed to 3.3k 1/4 watt.
240VAC switching.
Gate Resistors - The original value for the gate resistors (item 7) was 180 ohms. For 240VAC operation, the gate resistors need to be changed to 360 ohms.
H11AA1 limiting resitors - These will need to be changed to 33k 2 watt. As this is not practical I am going to suggest another option.
Operating the H1AA1 at 240VAC does not seem practical, given the required wattage of the 33k resistors at 2 watts. What I would suggest is making the additional modifications.
1. Cut the track from the Hot (active Trace) to the H1AA11 Resistor. This will isolate the H1AA11 from the TRIAC voltages 240VAC, and all the next step.
(need a picture to show where the track is located)
2. Fit two 3.3k (need a new value, maybe 2.2k) resitors for the H1AA11 circuit. The circuit will operate from the secondary of the transformer that will power the controller.
3. solder a wire from the hot H1AA1 resistor to the Hot input of the PCB.
Computer feed/power cable
Now you have installed all the parts, the next decision is how you will connect the controller to the PC, and how you will power the board.
The majority of the controller is run from a 5 volt DC regulator that is located on the PCB. The regulator is a 7805, and will provide a regulated 5VDC supply. The input voltage for the controller needs to be at least 9 VDC and no more than 15 VDC.
Checking the datasheet for the 7805, the minimum input voltage must be 2.0V greater than the V(out) = 7.0 V and with the input power diode (1N4001) having a Maximum Instantaneous Forward Voltage Drop of 1.1V, the absolute minimum is 8.1V.
