Sequencing with RGB Channels
Documentation still to be developed. Feel free to help!
To be written:
- Basic Effects with RGB Channels
 - Managing Color
 - The HLS toolbar with RGB Channels
 - Chases and RGB Channels
 - Fill Effects with RGB Channels
 - Custom Effects and RGB Channels
RGB Channels are a special channel in HLS that consist of three output channels each. These would generally be used with RGB strings and display items, both "dumb" RGB and Pixels. However, they can also be used to reduce channel counts of "mega strings", or strings composed of three different color strands which are contained together in one.
RGB Channels in the Sequence Window
RGB Channels, when displayed in the sequence window, will place "RGB" in front of the HLS Channel name. This helps distinguish which HLS channels are RGB channels. When adding effects to RGB channels, HLS will use a white color by default. Once you have added white effects, you can right-click on the effects, choose Modify, and change the color.
| Over Control Effects | Chapter 5: Sequencing Channels and Adding Effects | Custom Effects |
