The PixelPlane Editor: MegaTree
Current as of Version 12K.
Spiral
A Spiral effect creates the look of a spiral of lights twisting around the tree.
The Options to customize the Spiral Effect:
 - Speed of Rotation: How fast should the spirals rotate (lower numbers mean faster).
 - Number of Bars: The number of bars to spiral. Each additional bar will add a new color (max 6). Additional bars after that will repeat the color additions.
 - Width of Bars: How wide the bars should be.
 - Spiral Spacing: How much space should there be between each spiral.
Vertical Bars
A Vertical Bar effect creates vertical bars that rotate around the tree.
 - Speed of Rotation: How fast should the bars rotate (lower numbers mean faster).
 - Number of Bars: The number of bars to rotate vertically. Each additional bar will add a new color (max 6). Additional bars after that will repeat the color additions.
Horizontal Bars
A Horizontal Bar effect creates horizontal bars that rotate up or down the tree.
Snow
A Snow effect creates random "snowing" randomly-colored pixels that float down the tree.
 - Sparkle: Effects how many snowflakes are white. To have all white snow, turn it up very high.
Meteor
A Meteor effect creates random meteors that streak down the tree.
Fireworks
A Firework effect creates fireworks that streak down the tree. These are exactly the same as meteors, except when sparkle is applied. When it is applied, it will randomly "explode" the firework.
- Speed of Rotation: How fast should fireworks come (lower numbers mean faster).
Horizontal/Vertical Bitmap
A Horizontal or Vertical Bitmap effect generates a bitmap file that scrolls across the tree horizontally or vertically.
Options to Customize a Bitmap Effect:
- Speed of Rotation: How fast the bitmap should rotate horizontally or slide vertically.
 - Injection Height: What height (in pixels) to start the bitmap.
 - Sparkle: Add random sparkling to the bitmap.
Selecting the Bitmap:
- Click the Bitmap File button and open your desired bitmap file.
 - Click the Height and Width buttons to let HLS know the dimensions of your file.
 - Click the Generate Bitmap file to complete setting up the file. Any changes to the file will require pressing the Generate Bitmap button again.
| The PixelPlane Editor | Chapter 6: The PixelPlane | The PixelPlane Editor: Vertical Matrix |
