4 Channel DCSSR Assembly Instructions
Background
Design
The board is a simple design, and follows the standard connection for an AC SSR COOP board. THe RJ45 Socket provided the connection to the Controller. The LED on the board indicates 5VDC is being supplied from the Controller to the OPTO.
The load switching is provided by MOSFETs. Mouser stock these parts, RFD14N05L, as part # 512-RFP14N05L512-RFP14N05L
The
Parts List
4 MOSFETs 512-RFP14N05L 1 OPTO 782-K847PH 5 680 ohm resistors 4 470 ohm resistors 4 10k resistors 1 LED 1 RJ socket 1 7805 or 78L05 5 538-39890-0302 Screw terminals
