Creating a PixelPlane
This documentation is incomplete.
Current as of Version 12C.
What is a PixelPlane?
How to Create a PixelPlane
- Assign the type of PixelPlane that you have and then click "Assign Type of PixelPlane."
 - Note:As of version 12H, only type "Mega Tree" is currently supported.
 - Complete the fields to help HLS understand your PixelPlane object, then click OK (See Figure 6-4).
In development.
Working With a PixelPlane
 - Note: Do not add the actual pixel channels to the display group. ONLY add the one PixelPlane channel. (See Figure)
 - Then, set the Display Group to the PixelPlane group to begin working on it (Manage Channels -> Select Display Group to Work on). It will show as a single channel. (See Figure)
Like any RGB channel, PixelPlane channels can have effects placed on them.
HLS has a built in PixelPlane Effect Editor, which can generate PixelPlane Effects.
HLS also supports dropping in effects from third parties, such as Nutcracker effects.
| Chapter 5: Sequencing Channels and Adding Effect | Chapter 6: The PixelPlane | The PixelPlane Editor |
