Talk:Quick Start Guide
OHR: The listing of the sections below are listed just as Jon Stevenson have them in his "HLS Getting Started Manual". I think they would work well for a HLS beginner. Any thoughts?
Installing HLS -  I believe the UGaRM for this section can be used with the modification of hiding the navigation table in the transcluded page.  This is done by using  <noinclude>  on each side of the table.
Modified the Download and Installation page as noted above and included it in the QSM on 2013-01-29.
Creating a Sequence   The UGaRM sections Starting a new HLS Sequence and Time Sequence are straight forward and should serve the QSG with minor  <noinclude>  additions.
2013-01-28 Modified the Starting a new HLS Sequence by  <noinclude>  the line "The next step is to tweak the Audio File." and the navigation table at the bottom of the page.  Transcluded the page into the QSG.
2013-01-29 Modified the Time Resolution by  <noinclude>  the navigation table out. Transcluded this page into the QSM "Creating a Sequence" transclusion immediately following the "Starting a new HLS Sequence".  It worked out very well!
Setting up Channels  I'm not sure the existing section in the UGaRM will work for this.
Configuring Groups
Adding or Deleting Channels
Creating a Preview
Adding a Beat Track
Configuring the Sequence for Output
Mirroring
Creating Custom Effects
Creating a library of Group Effects
Play From a Mark
Changing the Play Speed
Apply an Over Control Ramp
Creating a Playlist and a Schedule
